| clutch install questions | |
jnalley_01
Posts : 48 Join date : 2013-09-10 Location : malaga ohio
| Subject: clutch install questions Fri Sep 13, 2013 1:10 pm | |
| My kit should be here today with that being said.... 1. How does eveyone get theres torqued right. 2. Do u reuse the nut or buy a new one or use any lock tite. 3.and if anyone has tips and tricks not on video i would love to hear Thanks | |
Posts : 601 Join date : 2013-03-10 Age : 53 Location : Charleston , WV
| Subject: Re: clutch install questions Fri Sep 13, 2013 1:20 pm | |
| I use a snap on 18v impact to put them on. DO NOT use loctite or any thread locking compound...you will be cutting the nut off next time (been there-done that). The most important advice I can give is , once you put the od's in (whether you use grease or not)...keep constant pressure on the cam-plate with your thumb , until you get the nut tight !!! An od getting flopped is the most common issue people have. It's not a hard job at all...if you watch the how to vids a couple of times , you'll be fine. | |
jnalley_01
| Subject: Re: clutch install questions Fri Sep 13, 2013 1:39 pm | |
| How do u torque urs down torque wrench or guess | |
wagon1
Posts : 38 Join date : 2013-07-08 Age : 52 Location : King George, Va
| Subject: Re: clutch install questions Fri Sep 13, 2013 2:43 pm | |
| I've had mine off several times and I do just like scottwv said. You must keep the cam plate held in and then tighten the nut until tight. You do not need to go overboard. I use a 19v Craftsman Impact. | |
jnalley_01
| Subject: Re: clutch install questions Fri Sep 13, 2013 3:10 pm | |
| Is there anyway to use torque wrench | |
| Subject: Re: clutch install questions Fri Sep 13, 2013 5:14 pm | |
| Yamaha has a tool to hold the sheave...or you can wedge a wooden block in there to hold it...pretty sure the primary is 100ft lbs , not sure off the top of my head on the secondary. I've never had one come off from using an impact , in fact , I've had to cut 2 off ...once from using thread locker , and the other because I used the air gun , instead of the cordless. If u opt to use a torque wrench , make sure and torque it AFTER you have the belt on , and riding where's its suppose to be...if not , the od's can flop , and you'll be doing it all over again. | |
| Subject: Re: clutch install questions Fri Sep 13, 2013 8:01 pm | |
| make sure v-belt runs same way you took it off (arrow should point towards rear) 700cc = 100 ft. lbs. primary sheave; 72 ft. lbs secondary sheave 660cc = 85 ft. lbs. primary sheave; 72 ft. lbs secondary sheave 450cc = 72 ft. lbs. primary sheave; 72 ft. lbs secondary sheave use a 6-point socket if you have one so you don't bugger up the nut nobody likes buggered up nuts
Last edited by 08Rhino450SE on Mon Sep 16, 2013 2:21 pm; edited 2 times in total | |
jnalley_01
| Subject: Re: clutch install questions Fri Sep 13, 2013 11:01 pm | |
| Ty eveyone only bad thing is the damn mail didnt bring......oh well be here sometime i figure mail seems to suck round here i was gonna track it but dunno how do that | |
jnalley_01
| Subject: Re: clutch install questions Fri Sep 13, 2013 11:03 pm | |
| Im like a kid on christmas but dunno what day christmas is lol | |
jnalley_01
| Subject: Re: clutch install questions Sun Sep 15, 2013 9:46 am | |
| Wow my bottom end feels like it wants to pull tires offground this this is wicked gold spring msd od rollers and jbs sheave freaking sweet.... like a new rhino | |
wagon1
| Subject: Re: clutch install questions Sun Sep 15, 2013 10:55 am | |
| Subject: Re: clutch install questions | |
