Who is online? | In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests :: 1 Bot None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | rear diff axle seal | |
southark
| Subject: rear diff axle seal Mon Oct 07, 2013 10:44 pm | |
| Ok guys got a problem that i cant figure out.I replaced the axle seal on the passanger side and it is still leaking when I ride at normal speeds .The other issue is that when I rode it after putting it back together the axle had come out of the diff just alittle.Has anyone had this happen before? | |
| | | rhino727
| Subject: Re: rear diff axle seal Tue Oct 08, 2013 1:21 am | |
| if the axle pulled out some may cause the leaking | |
| | | cammoup
Posts : 104 Join date : 2013-11-07 Age : 60 Location : Birmingham, AL
| Subject: Re: rear diff axle seal Thu Nov 07, 2013 9:16 pm | |
| Axle popping out happened to me once. I googled it and found this solution. I havent done it yet because I need axles.
High Lifter Gorilla Axle Clip- Rear Inner 04-07 660.
If you google it look for the Amazon Article $16.99 each + $8.95 S/H. It says Gorilla ATV would be the place to contact if they are sold out on Amazon. Only 1 left as I type this
J.R. | |
| | | 123.bert0621
| Subject: Re: rear diff axle seal Fri Nov 08, 2013 12:11 am | |
| The clip should be replaced every time it is removed but I myself haven't done it I sure that I am not the only one. | |
| | | cammoup
| Subject: Re: rear diff axle seal Fri Nov 08, 2013 12:15 am | |
| Probably why my axle keeps popping out. Never know when you buy someone else stuff. I spent a lot of time getting it right and while speeding through a field I hit a hog rooting hole and the entire axle popped out. I was lucky. I feel better changing the axles just in case.
J.R. | |
| | | 123.bert0621
| Subject: Re: rear diff axle seal Fri Nov 08, 2013 12:23 am | |
| You were lucky I have bought the used stuff to,and most times it works fine, but other times a little recondition is required a good way to save money though. | |
| | | cammoup
| Subject: Re: rear diff axle seal Fri Nov 08, 2013 12:55 am | |
| - 123.bert0621 wrote:
- You were lucky I have bought the used stuff to,and most times it works fine, but other times a little recondition is required a good way to save money though.
Sorry I was talking about the Rhino, wouldnt ever knowingly by/ trust a used axle. | |
| Subject: Re: rear diff axle seal | |
