Posts : 104 Join date : 2013-10-15 Age : 38 Location : Celina,OH
Subject: Re: servicing clutch Tue Oct 22, 2013 3:56 pm
Well seams the internals of my primary need replaced so what's best replacement parts to go with
Subject: Re: servicing clutch Tue Oct 22, 2013 6:52 pm
do you have a JBS sheave now ? if not CALL James will be the best mod you can do an you will love it
Wht07rhino
Subject: Re: servicing clutch Tue Oct 22, 2013 7:48 pm
purchased rhino 2 weeks ago.. would like to gry one be funds say otherwise right now... here is picture of the sheave support shat and close up of cam plate and weird square markings I already need a new cam plate so gonna get new shaft as well....any ideas whats the cause
Wht07rhino
Subject: Re: servicing clutch Tue Oct 22, 2013 7:49 pm
Subject: Re: servicing clutch Tue Oct 22, 2013 8:52 pm
is that scorched from heat?
how's the primary sheave look?
Subject: Re: servicing clutch Tue Oct 22, 2013 8:56 pm
I'm sorry but I'm still saying something was there. Maybe not when you took it apart, but something was there. I wonder if someone sold him a shim and the previous owner installed it wrong? There's no way two round parts can wear into a square. I watch enough Sesame Street in my life it know this. Lol
Bayou Tiger
Subject: Re: servicing clutch Tue Oct 22, 2013 9:12 pm
My opinion for what it's worth. Looks like the cam plate and collar weren't touching completely and got water or contaminates in between and stained both pieces.
Wht07rhino
Subject: Re: servicing clutch Tue Oct 22, 2013 9:56 pm
I have only took this part off motor so far working out of town and a full time and two part time jobs don't leave much wrench time.....as far as a contaminate more then likely was probably never services took 4 hrs in parts washer to grease out......took a straight edge across end of shaft and couldn't get a .0015 fealer gauge under it on all sides of the squared rub marks... try to get rest off this weekend
Subject: Re: servicing clutch Wed Oct 23, 2013 10:10 am
Just looks very interesting for sure. James can hook you up with whatever parts you need to get back going again. Time to stop wrenching and start riding on those days off
Subject: Re: servicing clutch Wed Oct 23, 2013 10:24 am
just for reference, this is what it's supposed to look like:
Subject: Re: servicing clutch Wed Oct 23, 2013 10:37 am
the cam plate is always tight against the collar even if the sheave dont move back to it..
Subject: Re: servicing clutch Wed Oct 23, 2013 10:42 am
That's what I'm saying James. Regardless of how much trash was in there, there's no way something could go between them. There had to be a square type washed installed there for this makes to be made. Which probably made excessive wear inside the cam plate and it kinda looks like the splines are a little worn down as well. The damage was done and he out it back stock after so it wouldn't do any further damage. The previous owner that is. Some people don't know Bette and listen to the wrong people like in that other crappy site. Lol
Subject: Re: servicing clutch Wed Oct 23, 2013 11:24 am
looks weird to me too..maybe camplate is bent
Wht07rhino
Subject: Re: servicing clutch Wed Oct 23, 2013 1:11 pm
Well james hit me up with cost to fix it up with your goods cause that's what its looking like I need new primary..might as well go with a good one... running 26" mudlites black rhino cdi and two brothers pipe....
Subject: Re: servicing clutch Wed Oct 23, 2013 1:28 pm
    that's it get the good stuff
Subject: Re: servicing clutch Wed Oct 23, 2013 1:29 pm
Make sure the fixed(one behind the primary) is straight aS well.
Subject: Re: servicing clutch Wed Oct 23, 2013 2:26 pm
how is the fixed and the belt
Wht07rhino
Subject: Re: servicing clutch Wed Oct 23, 2013 2:28 pm
Belt fixed looks good haven't taken time to look it over to much ...throw in new belt
Subject: Re: servicing clutch Wed Oct 23, 2013 2:40 pm
make sure the fixed is perfect or it will cause damage to the new stuff
Subject: Re: servicing clutch Wed Oct 23, 2013 2:49 pm
360 for the kit,spring,camplate and shipping in the us
Wht07rhino
Subject: Re: servicing clutch Wed Oct 23, 2013 3:32 pm
On fixed side what tell tale signs of problems should I be looking for as dar as wear?... what should one look like?
Wht07rhino
Subject: Re: servicing clutch Wed Nov 06, 2013 9:23 am
Well rhino motor is out for mid gear plate update.... and while its gonna be a part I'm gonna slug the wet clutch do to good reviews on here about it.. but my questions are as follows..I wanna eventually get a JBS sheave for it and will slugging the wet clutch be a waste of time.....what all is included with a JBS sheave kit ....James if you could chime in would be great..... thanks Eric
chalkminer
Subject: Re: servicing clutch Wed Nov 06, 2013 11:25 am
slugging the wet clutch and the JBS sheave are great mods that work great together.
Subject: Re: servicing clutch Wed Nov 06, 2013 11:29 am
A good place to start understanding the CVT parts is some vids on Hotrods Youtube channel. Here is a good one to get You started.......look through His vids and You will find a vid on about every part of the CVT
Subject: Re: servicing clutch Wed Nov 06, 2013 11:36 am
it will work great together...the kit will include sheave,weights,sliders,anti friction washers... it will depend on mods and wear as far as the rest of the parts needed...spring,fixed,belt,ect
