Who is online? | In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests :: 2 Bots None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | Rhino Stalls after Idling a long time | |
cammoup
Posts : 104 Join date : 2013-11-07 Age : 60 Location : Birmingham, AL
| Subject: Rhino Stalls after Idling a long time Thu Nov 07, 2013 6:14 pm | |
| Wast sure where to post this.
Yesterday while changing some hunting equipment around I idled my Rhino while working.
After about 30 minutes of idleing (trying to burn some fuel off for winterization), it stalled. Temp indicator good. Thought out of fuel. Checked fuel all is good 1/2. Started right back up and idled again for about 30 minutes and stalled.
Is there some type of fail safe built in to 05 Rhinos?
I have never idled it that long before so just wondering. Idle is fine, oil fine, temp fine. I have an altinator and battery voltage is 13.7.
Just wondering.
Thanks
J.R. | |
| | | 08Rhino450SE
| Subject: Re: Rhino Stalls after Idling a long time Thu Nov 07, 2013 6:23 pm | |
| how old is the fuel? mine used to stall when i first bought it i've been making sure it's fresh, especially in the late fall when it will sit a lot more. too much freakin ethanol in fuel these days. (all the volatility evaps away) | |
| | | cammoup
| Subject: Re: Rhino Stalls after Idling a long time Thu Nov 07, 2013 6:27 pm | |
| - 08Rhino450SE wrote:
- how old is the fuel?
mine used to stall when i first bought it i've been making sure it's fresh, especially in the late fall when it will sit a lot more. too much freakin ethanol in fuel these days. (all the volatility evaps away) Fuel is only about 1 month. Fresh fuel just before axle popped out. I also use SeaFoam in my fuel and have never had a problem but as I mention never idled that long. J.R. | |
| | | Firefighter
| Subject: Re: Rhino Stalls after Idling a long time Thu Nov 07, 2013 6:44 pm | |
| Mine has always done that. | |
| | | cammoup
| Subject: Re: Rhino Stalls after Idling a long time Thu Nov 07, 2013 7:00 pm | |
| - Firefighter wrote:
- Mine has always done that.
Great to know, thanks for all of the replies. J.R. | |
| | | Firefighter
| Subject: Re: Rhino Stalls after Idling a long time Thu Nov 07, 2013 7:13 pm | |
| Seems like somebody explained that on here before. At an idle, the intake is not supplying enough vacuum to operate the fuel pump.
Always meant to ask some of the guys that run electric fuel pumps if theirs dies after idling for a while | |
| | | cammoup
| Subject: Re: Rhino Stalls after Idling a long time Thu Nov 07, 2013 7:16 pm | |
- Seems like somebody explained that on here before. At an idle, the intake is not supplying enough vacuum to operate the fuel pump.
Always meant to ask some of the guys that run electric fuel pumps if theirs dies after idling for a while I couldnt find info through searching, probably didnt put the correct words in. I will be adding electric fp pretty soon once I get some upgrades done, cam etc. J.R. | |
| | | rhinosport84
| Subject: Re: Rhino Stalls after Idling a long time Thu Nov 07, 2013 8:07 pm | |
| mine did the same thing when I first bought it I just turned the idle up just a little also added a high flow fuel pump an fuel lines now I can idle it all day if I want | |
| Subject: Re: Rhino Stalls after Idling a long time | |
