In total there are 96 users online :: 0 Registered, 0 Hidden and 96 Guests :: 1 Bot
terex shock spring question Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
terex shock spring question Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
terex shock spring question Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
terex shock spring question Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
terex shock spring question Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
terex shock spring question Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
terex shock spring question Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
terex shock spring question Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
terex shock spring question Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
terex shock spring question Vote_lcapterex shock spring question Voting_barterex shock spring question Vote_rcap
2 posters
jaydub
terex shock spring question Empty
PostSubject: terex shock spring question   terex shock spring question Icon_minitimeTue Nov 12, 2013 2:07 pm
I have terex shocks on the rear of my rhino with black springs. I have them adjusted all the way up but with all the weight im toting I need more spring. Anybody know a source?
PostSubject: Re: terex shock spring question   terex shock spring question Icon_minitimeTue Nov 12, 2013 2:09 pm
you have the spring all the way down or compression?
jaydub
PostSubject: Re: terex shock spring question   terex shock spring question Icon_minitimeTue Nov 12, 2013 3:19 pm
I dont understand your question james. I have the spring adjusted as tight as it will go. Stiffest. Haven't messes with anything else. I dont know much about shocks. Are you saying I can adjust the fluid portion of these?
That would be awesome if so.
jaydub
PostSubject: Re: terex shock spring question   terex shock spring question Icon_minitimeTue Nov 12, 2013 3:20 pm
PostSubject: Re: terex shock spring question   terex shock spring question Icon_minitimeTue Nov 12, 2013 4:54 pm
some are...get some pics
» another teryx shock question
» Shock suggestions? 700 rhino
» Shock bolts
» Shock help ASAP
» Adding a lift kit to restore stock height
