| 660 differential mount/support | |
+3Wht07rhino rhino727 Baxter Built Fabrications 7 posters |
| Subject: 660 differential mount/support Thu Nov 14, 2013 2:13 am | |
| Guys,I have another 660 in the shop.A perfect model to make a real fix for the 660 chassis flaw.What I haven't told you is my first 660 chassis diff mount/support mod was a total disaster.I wish I had pics of what we did but I don't.When his Rhino went problematic I basically fixed it the same way every diff support I've seen on the market does for support.The problem is he used the receiver box in the back of the chassis.He got stuck bad enough they jerked on it and the leverage applied from the receiver broke the extra bottom bosses off the differential.Then I went threw the hassle that I did on the last one you seen in here.My fix will not be as easy to install but if the mount is already damaged it will fix the issue.I'll update this tomorrow as I get further into it.I'm trying to make this as painless as possible but I can see now way around welding.This will however update it far and beyond the 700 chassis update from the 660 model that Yamaha did. | |
Posts : 1317 Join date : 2013-03-25 Age : 60 Location : musella,Ga.
| Subject: Re: 660 differential mount/support Thu Nov 14, 2013 9:58 am | |
| do u plan on possibly selling one like your last repair I think u would move quite a lot of that design know I would grab one fast as possible | |
| Subject: Re: 660 differential mount/support Thu Nov 14, 2013 10:12 am | |
| It will be similar to the last one, minus cutting the factory mount out of it and using a jig.I'll post pics when I get back to the shop. | |
Wht07rhino
Posts : 104 Join date : 2013-10-15 Age : 39 Location : Celina,OH
| Subject: Re: 660 differential mount/support Thu Nov 14, 2013 11:56 am | |
| Baxter..I own copyright laws to the wht rhino..... hahaha..... this is the first of several BBF parts for this machine | |
| Subject: Re: 660 differential mount/support Thu Nov 14, 2013 9:23 pm | |
| lol,I hope to finish yours up tomorrow night Wht07. | |
| Subject: Re: 660 differential mount/support Fri Nov 15, 2013 4:09 am | |
| I'll get a price worked up for the kit if anyone is in need of one. | |
| Subject: Re: 660 differential mount/support Sat Nov 16, 2013 1:25 am | |
| Here is a pic of the pieces I made to drop in the top.I just need to make some spacer to go in between the plate and the factory mount and a longer bottom bolt.i'll try to make some instructions to help. | |
Crusty
Posts : 431 Join date : 2013-08-10 Age : 55 Location : Woods Cross Utah
| Subject: Re: 660 differential mount/support Sat Nov 16, 2013 1:45 am | |
| Oh great now I'm going to have to use my Awesome welding skills lol Well they're not too bad until I have to overhead weld then I think I have more slag on my neck than weld on material lol | |
| Subject: Re: 660 differential mount/support Sat Nov 16, 2013 2:23 am | |
| lmao! There will be no overhead here so you should be golden.lol I've never heard it quite put that way before but that's funny. | |
Posts : 988 Join date : 2013-03-10 Age : 57 Location : Mt. Pleasant , Pa
| Subject: Re: 660 differential mount/support Sat Nov 16, 2013 9:57 am | |
| Great Idea. How much are they going to be ? | |
| Subject: Re: 660 differential mount/support Sat Nov 16, 2013 10:41 am | |
| I'll let you know asap.Trying to get this one done, hardware and all,and make sure there is nothing else to add. | |
| Subject: Re: 660 differential mount/support Sat Nov 16, 2013 1:25 pm | |
| Subject: Re: 660 differential mount/support Wed Nov 20, 2013 1:24 am | |
| Last piece of the puzzle going in the Rhino on the lift. I'll have diff mount/supports coming very soon.It's going very smooth in this Rhino considering the Rhino is pretty busted up.I'll have a drill bit ,as an option, in the kit. This 12" 7/16 drill bit makes it so you don't have to take the diff completely out.I'll make that your decision.The shop is filling up with these things. Lol | |
| Subject: Re: 660 differential mount/support Wed Nov 20, 2013 1:46 am | |
| in picture of mount is that the fill plug behind the mount if so can u get plug out an be able to add fluid if needed . | |
| Subject: Re: 660 differential mount/support Wed Nov 20, 2013 3:06 am | |
| I think it's just the way the picture looks.There is plenty of room there but I will look at it tomarrow because it almost has me convinced it's in the way.lol | |
| Subject: Re: 660 differential mount/support Wed Nov 20, 2013 11:00 am | |
| cool if it's not put my name in pot for one when u start selling them | |
| Subject: Re: 660 differential mount/support Wed Nov 20, 2013 10:02 pm | |
| Subject: Re: 660 differential mount/support Wed Nov 20, 2013 10:06 pm | |
| Here is a over head pic of it before I welded it in. | |
Crusty
| Subject: Re: 660 differential mount/support Wed Nov 20, 2013 10:08 pm | |
| As soon as this motor is paid for I will be ordering 2 kits. Awesome job and the price is right! | |
| Subject: Re: 660 differential mount/support Thu Nov 21, 2013 1:27 am | |
| after I get back to work an catch up some fun funds I will get one right after the new year , an x2 on price | |
| Subject: Re: 660 differential mount/support Thu Nov 21, 2013 1:28 am | |
| Nice kit , post your contact info | |
| Subject: Re: 660 differential mount/support Thu Nov 21, 2013 3:55 pm | |
| Just let me know.I'm busy posting it on other sites but I have 8 sets ready to ship at this moment. | |
| Subject: Re: 660 differential mount/support Mon Nov 25, 2013 4:07 pm | |
| Mounts are in the mail Jay.Thanks | |
| Subject: Re: 660 differential mount/support Mon Nov 25, 2013 4:31 pm | |
| alot of the cross tubes breaks too that i seen..maybe you can add one that you slide in the stock tube to beef it up too | |
| Subject: Re: 660 differential mount/support Tue Nov 26, 2013 11:28 pm | |
| I see what your saying James.I might try that on the next one.I put a support on the bottom of the last one after I jacked it back up straight.It wasn't very user friendly and wouldn't advise someone to loose their knuckles putting it in.lol The twisting motion that the factory mounts allow is what fatigues that back tube till it finally cracks. I looked at 2 more 660 Rhinos last night.One appeared to be fine the other the front mount on the rear diff. had a hairline crack in it.The one with a crack was bone stock and only had 1800 miles .I'm making it a point to look at as many of them I can find.He had a 3rd at his shop that we couldn't get to.I'll let him get caught up and go back at a later date.The guy I sold a kit to yesterday had one of the diff supports that bolted to the receiver box and it broke the boss off the diff.and ironically I found 2 places advertising the receiver style supports and claimed it's to avoid cracking of the aluminum diff housing.I've seen plenty of these Rhinos thrashed and trashed and have never seen the housing break unless it had a receiver mounted support on it.lol It's the sheet metal tabs holding the housing in that let's go.I'm not saying that the receiver mounted supports are junk by no means.Any extra support is better than none. I'm just saying there is a flaw there that could possibly make a mess. | |
| Subject: Re: 660 differential mount/support | |
