In total there are 70 users online :: 0 Registered, 0 Hidden and 70 Guests :: 3 Bots
Got a problem Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Got a problem Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Got a problem Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Got a problem Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Got a problem Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Got a problem Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Got a problem Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Got a problem Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Got a problem Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Got a problem Vote_lcapGot a problem Voting_barGot a problem Vote_rcap
 Got a problem
4 posters
Dizzledog1
Dizzledog1
Got a problem Empty
PostSubject: Got a problem   Got a problem Icon_minitimeSun Nov 17, 2013 6:47 pm
I went to change my brake pads and noticed one of the pad pins had been hit by something. And the head is striped. Beyond drilling it out. What can I use to extract the pin. I've used ez-outs in the past and not had much luck with them I usually break them off. If I can find one I think a t35 star bit would work but no one has one around here . Any suggestions ? Thanks in advance.
Got a problem Empty
PostSubject: Re: Got a problem   Got a problem Icon_minitimeSun Nov 17, 2013 7:15 pm
T-35 TORX should be easy enough to find, if you can get the tool to grip at all, you should heat the pin before applying to much torque to it. I bought new pins for mine to replace any damaged, don't forget to clean and lube the sliders and pads and pins with dielectric compound. The caliper pins are Allen head 6mm I think.
Dizzledog1
Dizzledog1
Got a problem Empty
PostSubject: Re: Got a problem   Got a problem Icon_minitimeSun Nov 17, 2013 8:00 pm
How do you clean and lube the sliders? I've got the grease for it just have never done it. Actually that was why I was taking it apart to begin with.
Got a problem Empty
PostSubject: Re: Got a problem   Got a problem Icon_minitimeSun Nov 17, 2013 9:13 pm
I wipe off any old dirt or grease, some 40 grit paper or if the dirt corrosion is real stuck I use my sandblaster.
Dizzledog1
Dizzledog1
Got a problem Empty
PostSubject: Re: Got a problem   Got a problem Icon_minitimeMon Nov 18, 2013 1:36 pm
Anyone know how to take the sliders out of the caliper. Not the pins that hold the pads but the actual slider that moves?
Got a problem Empty
PostSubject: Re: Got a problem   Got a problem Icon_minitimeMon Nov 18, 2013 3:07 pm
They just pull out of the rubber boots.
Dizzledog1
Dizzledog1
Got a problem Empty
PostSubject: Re: Got a problem   Got a problem Icon_minitimeMon Nov 18, 2013 5:38 pm
Thanks for the info. Never done it so I thought I would ask
Got a problem Empty
PostSubject: Re: Got a problem   Got a problem Icon_minitimeMon Nov 18, 2013 5:51 pm
No problem.
Got a problem Empty
PostSubject: Re: Got a problem   Got a problem Icon_minitimeWed Nov 20, 2013 11:42 am
You might want to consider getting a new caliper if it's beat up beyond repair. I bet James could set you up.
Got a problem Empty
Got a problem
» Steering problem ??????
» JBS Sheave PROBLEM
» Problem with hood clips
» Rhino 700 Electrical Problem - Solved!
