| What kind of snow plow setups is everyone running? | |
+6CamoRhino660 Wht07rhino flimmy madmax 1 mike734 NickH 10 posters |
NickH
Posts : 83 Join date : 2013-08-21 Age : 51 Location : Northern Cambria, Pa
| Subject: Re: What kind of snow plow setups is everyone running? Sun Nov 24, 2013 12:32 pm | |
| Wishing I had one right now anyway, we got about 6 inches of snow last night. It started yesterday afternoon so we decided to take the Rhino out for our first snow ride. The roads were a sheet of ice but the trails were fun. Might have to go out again today. | |
| Subject: Re: What kind of snow plow setups is everyone running? Sun Nov 24, 2013 5:30 pm | |
| - NickH wrote:
- Hump, how high will yours lift?
Not very high. Maybe about 8 -10" if I were gonna guess. | |
CamoRhino660
Posts : 253 Join date : 2013-03-10 Age : 46 Location : Hayesville,Ohio
| Subject: Re: What kind of snow plow setups is everyone running? Sun Nov 24, 2013 8:00 pm | |
| I turned the mounting bracket backwards from t how they tell you to put it on and it lets the plow raise much higher prb around 2' or so. | |
Posts : 681 Join date : 2013-04-30 Age : 47 Location : Limerick P.A.
| Subject: Re: What kind of snow plow setups is everyone running? Sun Nov 24, 2013 9:19 pm | |
| - Hump wrote:
- Get the longer push tubes not that crap that mounts right up front. My Dad had that setup once and it just makes the plow dig in and the machine try to run over it instead of pushing the snow. We hated it. I got a 60" cycle country plow and love it. A little wider would be better, but it is just even with my tires when tilted to one side.
to each is own. I never had a problem with mine digging. I wanted the setup I got over the one with the push tubes. its a lot eaiser to hook up and it lifts a lot higher. the extra lift height helps make larger piles of snow and it makse it easy to load on and off a trailer without removing the plow from the rhino plus I needed it to lift really high because I have a steep ramp going into my shed. | |
Posts : 988 Join date : 2013-03-10 Age : 57 Location : Mt. Pleasant , Pa
| Subject: Re: What kind of snow plow setups is everyone running? Wed Nov 27, 2013 5:52 pm | |
| Nick , I just got off the phone with Moto Alliance and they said the push tubes are the same as whats on the Pro series plows. | |
ssol
Posts : 28 Join date : 2013-11-27 Age : 67 Location : LAPPE ONTARIO(RURAL THUNDER BAY AREA) CANADA
| Subject: PLOWS Sat Nov 30, 2013 12:11 pm | |
| I WELDED A 2 IN TUBE TO PLOW BRACKET AND JUST SLIP IT IN AND OUT OF MY FRONT RECEIVER FAST AND EASY WORKS GREAT | |
Deuces wild
Posts : 431 Join date : 2013-03-10 Age : 50 Location : central va.
| Subject: Re: What kind of snow plow setups is everyone running? Sun Dec 01, 2013 12:25 am | |
| Do you still need the plow strap if you have syn rope on your winch? | |
| Subject: Re: What kind of snow plow setups is everyone running? Sun Dec 01, 2013 1:14 am | |
| - Deuces wild wrote:
- Do you still need the plow strap if you have syn rope on your winch?
I don't know, but I'm fixin to find out this winter. 1st year with syn rope. I got that wear guard thing on the 1st 4ft or so, so I hope that is enough to save it. I think it really depends on how much you use it. We will see. If it doesn't hold up, I will go back to cable as much as that would suck. | |
| Subject: Re: What kind of snow plow setups is everyone running? Sun Dec 01, 2013 10:08 am | |
I don't know, but I'm fixin to find out this winter. 1st year with syn rope. I got that wear guard thing on the 1st 4ft or so, so I hope that is enough to save it. I think it really depends on how much you use it. We will see. If it doesn't hold up, I will go back to cable as much as that would suck. why chance it. simple fix. leave your syn line on and remove your hook. get an old wrachet strap you only need the long end not the wrachet itself. loop the strap thru your syn line about 12" no need to tie it and wind it up covering your syn line. and use just hook the other end to the plow. works great just make sure its a strap rated for 1000lbs or more. I snapped a strap rated for 500lbs. | |
| Subject: Re: What kind of snow plow setups is everyone running? Sun Dec 01, 2013 10:10 am | |
| I`ll can try to get ya step by step pics this week if you want. | |
| Subject: Re: What kind of snow plow setups is everyone running? Sun Dec 01, 2013 5:10 pm | |
| Subject: Re: What kind of snow plow setups is everyone running? Sun Dec 01, 2013 5:27 pm | |
| yea mike that's a great idea no sense in tearing up expensive syn line | |
| Subject: Re: What kind of snow plow setups is everyone running? Sun Dec 01, 2013 7:08 pm | |
| thank guys. ive been using that setup for 2 years without a problem. the thin flat profile fit my warn drum fine over top of my cable . so no need to remove you line or cable. I did forget to mention I swapped out the hook for a threated link extender. | |
| Subject: Re: What kind of snow plow setups is everyone running? | |
