In total there are 61 users online :: 0 Registered, 0 Hidden and 61 Guests :: 1 Bot
Cam n MSD installed - Page 2 Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Cam n MSD installed - Page 2 Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Cam n MSD installed - Page 2 Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Cam n MSD installed - Page 2 Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Cam n MSD installed - Page 2 Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Cam n MSD installed - Page 2 Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Cam n MSD installed - Page 2 Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Cam n MSD installed - Page 2 Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Cam n MSD installed - Page 2 Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Cam n MSD installed - Page 2 Vote_lcapCam n MSD installed - Page 2 Voting_barCam n MSD installed - Page 2 Vote_rcap
 Cam n MSD installed
Randy3451
ararhino
10 posters
Go to page : Previous  1, 2
Cam n MSD installed - Page 2 Empty
PostSubject: Re: Cam n MSD installed   Cam n MSD installed - Page 2 Icon_minitimeThu May 30, 2013 4:45 pm
Well guys to revisit this post and i have some new info to share with you... to recap i was having an issue with the motor being hard to start and boggin pretty bad at off idle rpm when you mash the throttle.. Well, after a few rides and holes later shes still going strong with the same issues... I grit my teeth everytime shes spins over for a bit but i know shes going to start..
Anyways, i recently snorkled my buddies rhino with the recomended size tubing that we figured you need.. Dual 2" piping going into the air box... My buddy has a raptor stock cam, msd 2d with no clutch work... We race on asphalt and are side by side and he leaves very much harder than i do pre snorkling...
Backed them out and lined them up with stock tires this time and i mashed the gas and smoked him.... Then after racing a few passes he went to start his and it spun over n over and then popped off.... Now, what does this mean????? The Snorkles are not in tune with the MSD.. Which makes more since cause of all the issues we are having... We made a few passes and we could see a huge difference between our two rhinos.. So, now the problem is how do i get my rhino to perform properly with the snorkles?? Answer is i have an appt set up with my Dyno guy in a month and we are going to find out exactly whats up with my little red monster
So, for all you guys that wanna run snorkles on an EFI or Carb motor, remember the length of tubing will effect the way the motor runs for sure... You will have to Dyno Tune
PostSubject: Re: Cam n MSD installed   Cam n MSD installed - Page 2 Icon_minitimeThu May 30, 2013 4:53 pm
you can do it with a air fuel gauge
PostSubject: Re: Cam n MSD installed   Cam n MSD installed - Page 2 Icon_minitimeThu May 30, 2013 5:12 pm
I have not delt with injection , would think it would be easier to tune than my carb was
PostSubject: Re: Cam n MSD installed   Cam n MSD installed - Page 2 Icon_minitimeThu May 30, 2013 5:27 pm
rather pay him a $100 to do it then me go and buy one for this one time use...
RHINOMOON
RHINOMOON
PostSubject: Re: Cam n MSD installed   Cam n MSD installed - Page 2 Icon_minitimeThu May 30, 2013 9:03 pm
hey banchee. i have cam and msd with alba maps and bunch other stuff. and i think yer kinda stuck with the slight low end bog cuz i have it too . but if you slug yer clutch.. its gone. imo. my rhino idles lumpy but its all good. its another different animal
PostSubject: Re: Cam n MSD installed   Cam n MSD installed - Page 2 Icon_minitimeThu May 30, 2013 9:08 pm
i have a loaner for all our customers
PostSubject: Re: Cam n MSD installed   Cam n MSD installed - Page 2 Icon_minitimeThu May 30, 2013 10:01 pm
if i was closer James id take you up on the offer... thanks for the help for sure... You should be getting a package next week some time from me... Just a little appreciation for all the help you have given me and my buddies....
PostSubject: Re: Cam n MSD installed   Cam n MSD installed - Page 2 Icon_minitimeThu May 30, 2013 10:04 pm
I know you mean... But, this guy has a Rhino with a raptor cam and other things as well..... if you know what i mean.... And, his runs preatty darn good... I seen video of him and an 800 in the sand side by side in 4 wheel drive... ran 64 on asphalt... but he is a Dyno MASTER....
Cam n MSD installed
» New 10" installed
» new sheeve is installed
» 40" light bar installed
» installed a stage 1 hot cam today
» Sheave Installed!!!!!!
