| Air filter adapter | |
+3CUSTOMIZEDRHINO13 onebuilder Firefighter 7 posters |
| Subject: Air filter adapter Sun Apr 07, 2013 8:55 pm | |
| Really wanting to buy a K&n air filter with adapter that allows You to clamp on the filter. Does anybody have a used one or know where a bargain is? Would like to find one cheaper than $120. | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 9:47 pm | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 9:52 pm | |
| WOW ! Is that for adapter filter and all ? can You run it with lid on ? | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 9:55 pm | |
| - Firefighter wrote:
- WOW ! Is that for adapter filter and all ? can You run it with lid on ?
Yes, complete, even the bolts! It flows really well. | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 9:59 pm | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 10:01 pm | |
| Have you heard of the RAIS snorkel mod for the top of the airbox lid?
I highly suggest it if you run with the lid on. Also, you will have to rejet the carb. | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 10:03 pm | |
| I run mine 04 style for less noise . | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 10:11 pm | |
| Any pics? Im not sure I know what the '04 style is. | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 10:14 pm | |
| 04 style is simple removing the factory snorkel that connects the airbox to the engine cowl. You can remove it and close off the engine cowl intake hole and all the intake noise is gone ! It also allows more air like the rais tube mod and yes I did have to re jet for it.
Onebuiler, Thanks for the great find ! Just ordered one ! | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 10:45 pm | |
| Happy to help!
Have you done any exhaust mods? | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 10:47 pm | |
| exhaust tip. It may just be mental, but it seems to have a lot better throttle response. | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 10:49 pm | |
- exhaust tip. It may just be mental, but it seems to have a lot better throttle response.
I'm running the Dragonfire Billet tip. It does help! Have you heard about grinding the welds on the header pipe flanges? It also helps on the low end. | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 10:51 pm | |
| I've read about it. Makes good sense. Would be a great rainy day project ! | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 10:54 pm | |
| When I looked at mine, i was like wow! Very restrictive. | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 11:05 pm | |
| Is there a gasket that will need to be replace while I'm there ? | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 11:12 pm | |
| You have the 2 donuts between the head and the header. Also, a sleeve at the coupler between header and muffler. If your careful, you can reuse them. | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 11:17 pm | |
| Good deal ! I have the sleeve for between the header and muffler. I will go ahead and get a couple donuts from James on a order I have, just in case. | |
| Subject: Re: Air filter adapter Sun Apr 07, 2013 11:21 pm | |
| Subject: Re: Air filter adapter Mon Apr 08, 2013 12:51 am | |
| I have one of those dragon fire intakes for my 700 to big for the lid though you can hear it sucking at idle I kinda like the sound.. | |
| Subject: Re: Air filter adapter Wed Apr 10, 2013 9:21 pm | |
| - onebuilder wrote:
- Cool!
Steve is the UNI filter just a foam type filter ? oil or dry ? | |
| Subject: Re: Air filter adapter Thu Apr 11, 2013 10:04 am | |
- onebuilder wrote:
- Cool!
Steve is the UNI filter just a foam type filter ? oil or dry ? Yes, foam type. UNI makes a oil and cleaner kit. It is about $12. | |
| Subject: Re: Air filter adapter Thu Apr 11, 2013 10:09 am | |
- onebuilder wrote:
- Cool!
Steve is the UNI filter just a foam type filter ? oil or dry ? Yes, foam type. UNI makes a oil and cleaner kit. It is about $12. Thanks Steve | |
| Subject: Re: Air filter adapter Fri Apr 12, 2013 1:25 pm | |
| Got my UNI filter and adapter installed. Very nice set up ! Not sure if I done the right thing on oiling it. Local bike shop sold me a can of foam air filter oil that they said is the best....HHmmmm. It looked just like K&N air filter oil but says it is for all foam filters. Have not noticed any huge increase in performance, but I already had a K&N and I only bought it for the adapter. It seals very well and that's what I was looking for. Thanks guys ! | |
CamoRhino660
| Subject: Re: Air filter adapter Fri Apr 12, 2013 5:34 pm | |
| When I oiled mine I just sprayed some oil on it then threw it in a zip lock bagie and rubbed the oil in that way. Saves having messy hands... | |
| Subject: Re: Air filter adapter Fri Apr 12, 2013 5:37 pm | |
| I used gloves, but that is a brilliant idea !!! | |
| Subject: Re: Air filter adapter | |
