In total there are 89 users online :: 0 Registered, 0 Hidden and 89 Guests :: 2 Bots
Air filter adapter - Page 2 Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Air filter adapter - Page 2 Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Air filter adapter - Page 2 Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Air filter adapter - Page 2 Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Air filter adapter - Page 2 Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Air filter adapter - Page 2 Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Air filter adapter - Page 2 Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Air filter adapter - Page 2 Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Air filter adapter - Page 2 Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Air filter adapter - Page 2 Vote_lcapAir filter adapter - Page 2 Voting_barAir filter adapter - Page 2 Vote_rcap
 Air filter adapter
7 posters
Go to page : Previous  1, 2
Air filter adapter - Page 2 Empty
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeFri Apr 12, 2013 9:46 pm
have the same k&n filter system on my rhino works real well
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeFri Apr 12, 2013 9:50 pm
Madmax, next time you have Your off, will You measure the adapter on the filter end and tell me what size it is? I may see if I can put a K&N on this adapter.
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeSat Apr 13, 2013 9:20 am
didnt mean to misinform you mine is a k&n w/outerwear
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeSat Apr 13, 2013 9:46 am
Yep, Mine has the UNI filter on it it, but in the future I may put a K&N on it if I can find a filter to fit this adapter. If You could tell me the outside diameter of the filter end of Your adapter, If they are the same, I could use the same K&N filter You use on mine.
Or If You could tell me Your filter #, I could look it up and see if it would fit my adapter.
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeSat Apr 13, 2013 9:54 am
will get back with you today
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeSat Apr 13, 2013 9:56 am
No big hurry. And Thanks a bunch !
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeSat Apr 13, 2013 2:01 pm
hey man, my filter adapt. is 2 1/2" and dont know if it helpson the bottom of filter (bo35b4) hope this helps you out
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeSat Apr 13, 2013 2:13 pm
Thats exactly what I needed ! Thanks Mick !
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeSat Apr 13, 2013 4:54 pm
any time bro
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeMon Apr 15, 2013 11:55 pm
onebuilder wrote:
Firefighter wrote:
exhaust tip. It may just be mental, but it seems to have a lot better throttle response.
I'm running the Dragonfire Billet tip. It does help!
Have you heard about grinding the welds on the header pipe flanges? It also helps on the low end.
Steve, I just pulled my header off and it is insane how big the welds are on it !!! Thanks Again !!
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeTue Apr 16, 2013 8:29 pm
let me know how yours turns out with performance gains i may do some grinding this weekend, any pics of the welds?
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeTue Apr 16, 2013 8:32 pm
Try to get some pics tonight
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeTue Apr 16, 2013 11:08 pm
Air filter adapter - Page 2 Photo_36
Air filter adapter - Page 2 Photo_37
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeWed Apr 17, 2013 11:04 am
don't mean to piss in your cheerios, guys, but they might be designed that way. that lip may help stop reversion (an exhaust pulse that goes back to the engine).
i don't pretend to be an expert, by any means, but sometimes engine porters will weld up the chambers in a "d" ring to stop reversion. just sayin' bounce
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeWed Apr 17, 2013 11:19 am
HAHA Too late now, I've already started grinding.
Very good point though.
I did read a very good thread on the RF sometime back on this mod though and most had very good results. I'll keep You posted.
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeWed Apr 17, 2013 11:21 am
No problem! Becareful not to make it to thin, the weld is what holds the flange to the pipe. I ground mine so it is flush, no problems for 6 years. I noticed a difference in the low end.
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeWed Apr 17, 2013 7:02 pm
good pics firefighter how did it go fer ya
PostSubject: Re: Air filter adapter   Air filter adapter - Page 2 Icon_minitimeWed Apr 17, 2013 7:26 pm
finish it up tonight ! I hope !
Air filter adapter
» Which Air Filter
» Oil filter number
» siphon hose and filter kit
» siphon filter and tube...
» Fuel filter empty while running
HOTRODRHINOFORUMS.COM :: Buy and Sell :: Want To Buy-
