| 27" tires & Hotrods clutch | |
+6rhino727 scottwv madmax 1 Hump CUSTOMIZEDRHINO13 Workhorserhino 10 posters |
Workhorserhino
| Subject: 27" tires & Hotrods clutch Thu Apr 18, 2013 9:34 pm | |
| [img][/img] I think this is cool. I just got done putting a RDC 2" lift on and SS212 rims with 27" Ultracross tires. Took my first run after setting toe in. Hotrods sheave is awesome. Its only slightly slower at get go in high gear. I think the only drawback at this time is the engine brack doesn't quite as good. Probably from the tire height. And that's with no maintinence on the clutch since I put it on. 16gr. weights and no grease, how I was told to assemble it. I know I will need to do something with it this year. James you are the Rhino KING! This forum is sooooo much better than rf. Hw sucks and I never ran there clutch! Next is additional lighting from Flimmy's website. Can ya tell I'm loving it. Anyway here is a pic of the tires. Sorry wrong pic, lets try again. | |
| Subject: Re: 27" tires & Hotrods clutch Thu Apr 18, 2013 9:44 pm | |
| Nice!!! | |
| Subject: Re: 27" tires & Hotrods clutch Fri Apr 19, 2013 4:17 am | |
| If you got a JBS sheave in your rhino, and Miller Lite in your fridge, that means life is good. You engine braking change is from the added height and weight of the tires. Mine slows down better with the sheave than it did stock with 25s. | |
| Subject: Re: 27" tires & Hotrods clutch Fri Apr 19, 2013 8:45 am | |
| looks real good, love my sheeve,is that all the beers it took for the install,you did pretty good | |
| Subject: Re: 27" tires & Hotrods clutch Fri Apr 19, 2013 1:14 pm | |
| Subject: Re: 27" tires & Hotrods clutch Fri Apr 19, 2013 7:41 pm | |
| wheel an tires look cool , cold beers look better | |
| Subject: Re: 27" tires & Hotrods clutch Fri Apr 19, 2013 7:49 pm | |
| Subject: Re: 27" tires & Hotrods clutch Fri Apr 19, 2013 9:06 pm | |
Snorhino
Posts : 159 Join date : 2013-03-10 Age : 59 Location : Central Maine
| Subject: Re: 27" tires & Hotrods clutch Fri Apr 19, 2013 10:09 pm | |
meats
Posts : 227 Join date : 2013-03-11 Age : 45 Location : upper michigan
| Subject: Re: 27" tires & Hotrods clutch Fri Apr 19, 2013 10:17 pm | |
| Subject: Re: 27" tires & Hotrods clutch | |
