| to much air? | |
+5rob1 rhino727 Stuntmanmike Kenny G jaydog13 9 posters |
| Subject: Re: to much air? Fri May 03, 2013 7:23 pm | |
Posts : 227 Join date : 2013-04-01 Age : 51 Location : TN
| Subject: Re: to much air? Fri May 03, 2013 8:57 pm | |
| Larry, thanks for the info. What was your idea of snorkeling? The "04 style"? I just did a quick temp job with my shop vac hose and loved the how it quieten it down. | |
Posts : 1317 Join date : 2013-03-25 Age : 60 Location : musella,Ga.
| Subject: Re: to much air? Fri May 03, 2013 10:01 pm | |
| I 'm tuning mine now will say that who ever put the a/f screw there decided where the worst spot could be an put it there big pain in ass to get to | |
| Subject: Re: to much air? Fri May 03, 2013 10:22 pm | |
| [quote="foyota86"]Larry, thanks for the info. What was your idea of snorkeling? The "04 style"? I just did a quick temp job with my shop vac hose and loved the how it quieten it down.[/quote
I tried snorkeling several times but never got it to run right. Just run 04 style now and stay out of the deep ! | |
| Subject: Re: to much air? Fri May 03, 2013 10:36 pm | |
| Subject: Re: to much air? Fri May 03, 2013 11:33 pm | |
| - foyota86 wrote:
- Ok. I just want to make sure I know what is 04 style is...
http://www.rc-trucks.org/yamaha-rhino-noise.htm
right? It's the little snorkel tube that runs between the air box and the intake on the engine cover, just pull it off. "04 Style", you can close off the intake on the cover and reduce the motor noise also. | |
| Subject: Re: to much air? Sat May 04, 2013 12:23 am | |
| Gotcha, clears it up. I hope to never get at azz level, so I should be good. I removed the little tube, but didn't block off intake on cover. | |
| Subject: Re: to much air? Sat May 04, 2013 12:26 am | |
| Willy, Blocking off the intake on the cover will reduce heat coming into the cab area also, and noise. | |
| Subject: Re: to much air? Sat May 04, 2013 12:36 am | |
| I will try that. Got a weekend of all rain, so I will tinker. What does everyone block it off with? I might have some black plastic that may work. Just cut to fit and silicone. | |
| Subject: Re: to much air? Sat May 04, 2013 12:57 am | |
| Well, it might be nice when it's cold to have that hot air pumping into the cab area. What ever you think will work for you works best, Partner!! | |
| Subject: Re: to much air? Sat May 04, 2013 1:09 am | |
| I've seen people just tape it off for a while to make sure it is what they want. If You like it. You can make it permanent. The only draw back I have seen to it is, Your air filter gets dirty faster. | |
| Subject: Re: to much air? Sat May 04, 2013 1:23 am | |
| Larry, Do you feel that blocking off the cowl induction will make that much of a diff after removing the snorkel? I've noticed air moving out more than in. | |
| Subject: Re: to much air? Sat May 04, 2013 1:26 am | |
| It helps a ton with noise by closing it off, but i think your intake probably gets a little cleaner air with it open. I've had mine closed off for a year now with no issues. Just dirty filter. | |
| Subject: Re: to much air? Sat May 04, 2013 1:38 am | |
| Someone need to come up with a good mod that will push clean cool air to the airbox inlet. It will need to come from under the hood for it to be clean. | |
| Subject: Re: to much air? Sat May 04, 2013 1:45 am | |
| - Firefighter wrote:
- Someone need to come up with a good mod that will push clean cool air to the airbox inlet. It will need to come from under the hood for it to be clean.
Yep, 10/4 Good Buddy!!! | |
| Subject: Re: to much air? Sat May 04, 2013 1:48 am | |
| That winch is an upgrade , what do you think of the synthetic rope? NICE!!! | |
| Subject: Re: to much air? Sat May 04, 2013 1:53 am | |
| Haven't tried the synthetic rope yet. Looks awful flimsy but is rated at 7700 lbs. Used steel cable 3 times and hated it all 3 times . HAHA | |
| Subject: Re: to much air? Sat May 04, 2013 2:06 am | |
| Seating in the office makes one soft. Need to get out there and jack some lumber!!! | |
| Subject: Re: to much air? Sat May 04, 2013 10:08 am | |
| Has anyone ever just relocated stock airbox to under the hood? Siphon break crank, leave short pipe from carb, flex duct to under hood, and place airbox there. It looks like it would fit. | |
| Subject: Re: to much air? Sat May 04, 2013 10:13 am | |
| From what I've seen, adding any pipe or tubing anywhere on the carb causes tuning issues. There have been people successfully doing it, but it is tuff ! | |
| Subject: Re: to much air? Sat May 04, 2013 12:05 pm | |
| going to change mine over to 04 style this weekend, do you think it will flow more or less than mine with the rais tube installed | |
| Subject: Re: to much air? Sat May 04, 2013 4:41 pm | |
| Not gonna snorkel, just 04 it and block/seal off inlet real good. Winter time unblock for a mini hand warmer. Heck, I am used to four wheelers so I will be in heaven in the rhino anyway. | |
| Subject: Re: to much air? | |
| to much air? | |
