| am i at risk for over heating my rhino in the mud? | |
+8rhino727 foyota86 REDRHINO64 scottwv banchee6 Jet chuddly RhinoGT350 12 posters |
RhinoGT350
| Subject: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 4:34 am | |
| ok every one who played in the mud in their rhino. i hit a few mud puddles in my rhino and i always had a concern of over heating. a few times mud covered my radiator. well as you can guess it is warm and some of the water in the mud dries off making it thicker mud or dried mud coating my radiator. any way, i believe that it will reduce flowing through the radiator removing the heat. as a result i am afraid that it will cause my engine to over heat. i have never had any over heating issues with my rhino. it is completely bone stock. so i often rinse it off with water first chance i get. has any one had this problem running through the mud? or is it no big deal. thank you in advance!! | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 6:35 am | |
| JBS sells mud guards for your radiator and it can be a problem if it gets packed with mud. But a little wont hurt as long as you wash it out. | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 6:50 am | |
| absolutely it is an issue. for the rhino get a set of JBS shields. if you have friends with a RZR get a set of jetsxsproducts shields for it. | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 7:34 am | |
| Get the shields and clean the radiator often. | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 8:03 am | |
| I'd for sure get the sheilds. I would also look into a temp gauge , and a fan over-ride switch. | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 8:09 am | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 8:35 am | |
| I am interested in the guards, anyone know what they run? | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 9:11 am | |
| all good points , an yes its a issue we ride mud a lot but what your talking is the reason my sons (grizzly)has radiator on top of rack out of mud ,my rhino I wash out often the guards, fan switch ,all help.....so does a 12 volt water pump to clean at any water supply on trail | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 9:20 am | |
| Aluminum bright works very good at getting all the mud out without having to presure wash it. The JBS Shields work good also. But in my 05 that I run in the deep mud most of the time the only solution is to mount it between the seats and roof, it never even gets hot while up there in clean air. | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 9:24 am | |
| Think the radiator shields are $35( not sure ). get a 20amp relay and a switch to use for a fan override. And keep it clean as much as possible. I noticed a difference with just my radiator shields. | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 9:37 am | |
| yea stuntman I had thought of putting mine behind me on the roll cage just never done it yet | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 10:30 am | |
| 40.00 shipped... | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 10:36 am | |
| - WV Hot Rod Rhino wrote:
- 40.00 shipped...
I was close!!! | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 10:38 am | |
RhinoGT350
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 11:23 am | |
| hay guys thanks for your great responces! few times i soaked it with mud, i pulled over first chance i got and washed it with water,, most of time little bottled water if needed. but hay this site rocks!!! thanks | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 11:26 am | |
| Yes this site does rock!!!!! I wonder who's bright idea this was???? Lmao | |
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 12:15 pm | |
| In addition to keeping the radiator clean, don't forget the oil cooler! | |
Yotehunter66 Moderator
| Subject: Re: am i at risk for over heating my rhino in the mud? Tue Apr 30, 2013 9:38 pm | |
| Make yourself a wand for cleaning it. You want to be careful about using a pressure washer. You can bend the fins and restrict air flow. | |
| Subject: Re: am i at risk for over heating my rhino in the mud? | |
