In total there are 28 users online :: 0 Registered, 0 Hidden and 28 Guests
Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Finally installed the JBS sheave…  Is that the Rev limiter? Vote_lcapFinally installed the JBS sheave…  Is that the Rev limiter? Voting_barFinally installed the JBS sheave…  Is that the Rev limiter? Vote_rcap
5 posters
chalkminer
chalkminer
Finally installed the JBS sheave…  Is that the Rev limiter? Empty
PostSubject: Finally installed the JBS sheave… Is that the Rev limiter?   Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeSun May 05, 2013 2:46 am
Finally got time to work on the Rhino, figured that box of
go fast from JBS had sat on the shelf way too long. Dropped in the MSD charge last weekend. It got 50 MPH and ran out of steam. Today I installed the Sheave, now it runs up
to 53 and just as it hits 54, it cuts out.
Is that the rev limiter? I am
currently running 25 inch car tires that
are noticeably heaver than the stock ones.
Other than the sheave and MSD charge it is a stock 07 660. If I ran a taller tire, could I get a higher
top speed?
PostSubject: Re: Finally installed the JBS sheave… Is that the Rev limiter?   Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeSun May 05, 2013 5:19 am
If You got the horse power, it will !
PostSubject: Re: Finally installed the JBS sheave… Is that the Rev limiter?   Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeSun May 05, 2013 8:47 am
like firefighter said if you got the horsepower, but generally the bigger the tires the more weight and slower you go
PostSubject: Re: Finally installed the JBS sheave… Is that the Rev limiter?   Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeSun May 05, 2013 10:49 am
you got rollers flopped over on install
chalkminer
chalkminer
PostSubject: Re: Finally installed the JBS sheave… Is that the Rev limiter?   Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeSun May 05, 2013 12:49 pm
I tore into it again today. All the weights seem to setting in there the way they were supposed to (kind of ramping up to the side with the grooves at the center)seems like the belt is traveling fine (starts out a little out of the secondary and runs up to where it is a little out of the primary. I have not finished buttoning it up today. Yesterday when I test drove it, the performance was good. I spent a lot of time spinning the tires and it ran right up to 53MPH, but when it tried to go past that it cut out seemed a lot like it used to (before the MSD) when I'd hit 40MPH. From what I have read it should be pretty hard to reach the rev limiter without more mods.
Dizzledog1
Dizzledog1
PostSubject: Re: Finally installed the JBS sheave… Is that the Rev limiter?   Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeSun May 05, 2013 1:10 pm
What top speed is your msd box set at? I installed mine and took off it hit rev limiter at 27 mph. Hooked it up to computer and realized it was set for kph not mph. Set it up right and hit 59 with no prob
chalkminer
chalkminer
PostSubject: Re: Finally installed the JBS sheave… Is that the Rev limiter?   Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeSun May 05, 2013 2:57 pm
Hmmm, it is just the MSD charge add-on for the 660. I don't think it has a top speed setting...
PostSubject: Re: Finally installed the JBS sheave… Is that the Rev limiter?   Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeSun May 05, 2013 9:09 pm
Thats what I have (MSD Charge) and mine limits out at 54 mph
chalkminer
chalkminer
PostSubject: Re: Finally installed the JBS sheave… Is that the Rev limiter?   Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeMon May 06, 2013 12:10 am
Thanks Firefighter! Looks like everything is working just right then. I am loving the new hotrod sheave. I think the tires have spun more in the last 24 hours then the previous 6 years! Dare I ask about the 2013 improvement in the sheave?
PS: big thanks to James and JBS for making my Rhino fly!
PostSubject: Re: Finally installed the JBS sheave… Is that the Rev limiter?   Finally installed the JBS sheave…  Is that the Rev limiter? Icon_minitimeMon May 06, 2013 12:15 am
Yep, sounds like You got it running good !
The 2013 Sheave is machined just a little different. It allows a 700 camplate to set tighter against the weights and allows more for wear of parts without loosing performance or the need for replacement.
» Sheave Installed!!!!!!
» Installed JBS Sheave - Need Help
» Got jbs sheave installed today
» Sheave installed today..
» JBS sheave and OD weights installed ! Couple ???s
