In total there are 22 users online :: 0 Registered, 0 Hidden and 22 Guests :: 1 Bot
My wet clutch is screwed Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
My wet clutch is screwed Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
My wet clutch is screwed Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
My wet clutch is screwed Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
My wet clutch is screwed Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
My wet clutch is screwed Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
My wet clutch is screwed Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
My wet clutch is screwed Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
My wet clutch is screwed Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
My wet clutch is screwed Vote_lcapMy wet clutch is screwed Voting_barMy wet clutch is screwed Vote_rcap
RHINOMOON
UnderDawg
14 posters
Go to page : 1, 2  Next
My wet clutch is screwed Empty
PostSubject: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeTue Apr 23, 2013 10:32 pm
I had a problem with my rhino not wanting to go into or come out of gear. It was like it was bound up. After a little reasrch I thought it might be the oneway bearing. So I pulled everything apart tonight and NOPE the oneway bearing is fine. Its everthing else that's bad
When I pulled the cover off and saw what I thought was roller bearings turned out to be the pins from the clutch. Oh well I just have to work some OT now lol When they fell out it took out the drum too
here are the pic's.
My wet clutch is screwed 20130411
My wet clutch is screwed 20130412
My wet clutch is screwed 20130413
My wet clutch is screwed 20130414
My wet clutch is screwed 20130415
My wet clutch is screwed 20130416
My wet clutch is screwed 20130417
http://www.trailbrightled.com
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeTue Apr 23, 2013 10:35 pm
ouch. how many miles on it, scott?
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeTue Apr 23, 2013 10:36 pm
James , I'll be giving you a call when I get the cash.
Anyone need a new 40" double row CREE led bar My wet clutch is screwed 2016508534
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeTue Apr 23, 2013 10:40 pm
I have no ide , I bought it used from a dealer last yr and he said he had put a new wet clutch in it. It doesn't have the dig display.
The clutch material at one end looked like it had a good amount of material on it but when the pins came out and the springs came off the shoes they didn't pull back in and just rode on the drum.
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeTue Apr 23, 2013 11:04 pm
flimmy wrote:
I have no ide , I bought it used from a dealer last yr and he said he had put a new wet clutch in it. ................
I'm wondering if something was not put together quite properly. It would seem possible that maybe something was left out (or some such thing) during a replacement of the shoes only. There might be a reason Yamaha only offers the whole assembly as a replacement. When you get a new one it might be helpful for all of us if you carefully compare the old vs the new.
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeTue Apr 23, 2013 11:06 pm
I have never seen a wet clutch do that before, That really sucks!
UnderDawg
UnderDawg
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeTue Apr 23, 2013 11:15 pm
Wow! sorry to hear that.
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeTue Apr 23, 2013 11:17 pm
I'll get some side by side shots when i get the new clutch. I'll be adding weights to the new one too
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeTue Apr 23, 2013 11:19 pm
Thanks , shit happens out could be worse
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeWed Apr 24, 2013 12:05 am
Looks like james is going to have an extra bright rhino!
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeWed Apr 24, 2013 12:21 am
He already has a bar he just needs to get his rhino fixed so he can get to use it and I'm already set up with a replacement clutch Dancing Banana
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeWed Apr 24, 2013 12:28 am
sorry to hear about the clutch just got mine from James a couple wk back ,just thought mine was shot if you can see what caused it to come apart please post think we all would like to know
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeWed Apr 24, 2013 1:11 am
How long were you having problems with the gear engagement and dis-engagement Scott? Looks like it really toasted things. Did the dealer replace the whole clutch or just the pads? Downtime sucks!
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeWed Apr 24, 2013 9:42 am
with all those metal sheaving's in your oil may want to flush several times after you put back together to try to remove the fine grind dust of metal just a thought I added weight to mine also super easy, little bird shot weighed out an melt to pore, good luck with it What a Face
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeWed Apr 24, 2013 9:52 am
I might try something a friend used to do when I was a kid. He would fill the crank case with kerosene and turn the motor over. Not start it just turn it over and then drain it. He would do it a few times then fill it with oil. He said it would clean everything out. I won't do it with the new clutch I'll just throw the old drum in add oil then pull the plug wire
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeWed Apr 24, 2013 9:59 am
wow...might wanna see if you can clean the oil pump screen too
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeWed Apr 24, 2013 10:11 am
Good idea where on the motor is it Laughing
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeWed Apr 24, 2013 10:34 am
might have to pull the stater cover off too to get it all out
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeWed Apr 24, 2013 10:51 am
can you get to the screen without going in cases ? the kerosene might be good had not heard that one in a while , over winter bought some for my heater in shop an holy shit at the price
RHINOMOON
RHINOMOON
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeThu Apr 25, 2013 12:02 am
wowzers...
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeThu Apr 25, 2013 11:07 am
put a strong magnet near the bottom of the crankcase and/or get a magnetic drain plug if you can find one. the first couple times you change the oil and filter take the magnet off and let the oil drain. you can also drag another magnet through the drained oil and/or split the filter to check for residual metal frags.
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeThu Apr 25, 2013 11:24 am
Thanks I was thinking last night about the magnetic drain plug. I just have to figure out the thread on the plug and try to find one with the same thread. I thought about putting a magnet on the filter also
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeThu Apr 25, 2013 11:30 am
no.. but there is a couple holes that would make it easier to flush out....
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeFri Apr 26, 2013 1:11 pm
magnetic plugs on ebay
krayg
PostSubject: Re: My wet clutch is screwed   My wet clutch is screwed Icon_minitimeFri Apr 26, 2013 2:55 pm
Gold plug sells them. They have a search feature where you can specify your year/make/model/engine.
» Wet clutch
» Oil on clutch
» clutch
» clutch
» mud in clutch!
