Who is online? | In total there are 28 users online :: 0 Registered, 0 Hidden and 28 Guests :: 2 Bots None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | My wet clutch is screwed | |
+10RHINOMOON WV Hot Rod Rhino Kenny G rhino727 CUSTOMIZEDRHINO13 UnderDawg Stuntmanmike SteveS 08Rhino450SE flimmy 14 posters | |
thekrust
| Subject: Re: My wet clutch is screwed Fri Apr 26, 2013 5:46 pm | |
| Is that clutch a OEM Yamaha or some cheap aftermarket crap the dealer threw in there to make it go away?? Never seen a Yammie clutch srew up like that. | |
| | | flimmy
| Subject: Re: My wet clutch is screwed Fri Apr 26, 2013 6:02 pm | |
| thanks guys I'll look at them tonight and I have no idea what make of the wet clutch the dealer put in. It was a Yamaha dealer. | |
| | | REDRHINO64
| Subject: Re: My wet clutch is screwed Fri Apr 26, 2013 6:11 pm | |
| Man thats a nasty looking clutch,good luck on the repair!! | |
| | | RHINOMOON
| Subject: Re: My wet clutch is screwed Sat Apr 27, 2013 1:05 am | |
| its sorta bad. i guess.. that sux buddy.. | |
| | | rhino727
| Subject: Re: My wet clutch is screwed Mon Apr 29, 2013 10:41 am | |
| theres another member in the (engine) treads that's had the same failure, may want to flush the oil cooler out as well , it the (grind dust ) got his cam journals main bearing and more , so you got lucky that way but you need to clean clean flush, magnet an any thing else you can think of to get that stuff out. know I long winded here but thought you want to know good luck with it | |
| | | Workhorserhino
| Subject: Re: My wet clutch is screwed Mon Apr 29, 2013 8:11 pm | |
| You might want to just get a new oil cooler. The metal may not come out of the cooler. Yrs ago I did some work on Fords. Their transmission warrenty required a new cooler. They said because of the internal design of it, it could not be flushed clean. 1 more thing to consider. | |
| | | flimmy
| Subject: Re: My wet clutch is screwed Mon Apr 29, 2013 10:35 pm | |
| I am going to replace the oil cooler with a bigger trans cooler and fan. I also need to put valve seals in so when I have the cover off I'll clean the cam and topend. | |
| | | rhino727
| Subject: Re: My wet clutch is screwed Tue Apr 30, 2013 8:45 am | |
| Subject: Re: My wet clutch is screwed | |
