Who is online? | In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests :: 2 Bots None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | Oil on clutch | |
+8EddieMc rhino727 chuddly CUSTOMIZEDRHINO13 Stuntmanmike ChrisH rhinosport84 weekendwarriorfsw32 12 posters | |
weekendwarriorfsw32
Posts : 22 Join date : 2013-03-18 Location : Bay area
| Subject: Re: Oil on clutch Sun May 05, 2013 7:20 pm | |
| Is it hard to add weight to the shoes? Also how hard is it to replace the wet clutch? Just undo the big bolt and pop it out? | |
| | | Stuntmanmike
| Subject: Re: Oil on clutch Sun May 05, 2013 9:42 pm | |
| Use an impact gun to take the nut off, But first look at your one way bearing, mark it if you have to because it only works one way. You can buy a slug kit from KMS for about $50. or look up" how to add weight to your wet clutch" Then all you need is a gasket | |
| | | weekendwarriorfsw32
| Subject: Re: Oil on clutch Mon May 06, 2013 7:22 pm | |
| Well got a hold of JBS today and got my new wet clutch order and weights for the shoes. Had no idea how far I was going to be getting into this but I have learned a lot about CVT transmissions and I hope by the end of this to have a pretty bad ass bullet proof setup! Will let you guys know how it all goes back together and how it works after! | |
| | | honda450sfm
| Subject: Re: Oil on clutch Tue May 07, 2013 8:13 pm | |
| Sounds like you performed the same maintenance as I did. You will be happy with the new found performance! | |
| | | rhino727
| Subject: Re: Oil on clutch Tue May 07, 2013 9:37 pm | |
| really listen to mike about the one-way, I 'm taking mine back apart to flip the one-way over , I thought for sure I had it right so really look at it good . you will like the clutch work good luck | |
| | | weekendwarriorfsw32
| Subject: Re: Oil on clutch Sun May 12, 2013 2:57 pm | |
| Will Do!! One other question I had is how important is the torque number on the wet clutch, I don't have a torque wrench that can torque the left handed thread on that one. Also how do you guys hold it so it wont turn when torquing? | |
| | | Stuntmanmike
| Subject: Re: Oil on clutch Sun May 12, 2013 4:17 pm | |
| I install it with an inpact gun and use my calibrated hand. Really tho just give it a good hit with an inpact gun and hold the clutch by hand, then bend down the metal tab on the flat spot and you will be good. | |
| | | rhino727
| Subject: Re: Oil on clutch Tue May 14, 2013 12:14 am | |
| when you finish let us know what thoughts you have about your mods | |
| Subject: Re: Oil on clutch | |
| | | | Oil on clutch | |
