In total there are 50 users online :: 0 Registered, 0 Hidden and 50 Guests :: 2 Bots
Seat belt recommendation Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Seat belt recommendation Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Seat belt recommendation Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Seat belt recommendation Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Seat belt recommendation Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Seat belt recommendation Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Seat belt recommendation Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Seat belt recommendation Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Seat belt recommendation Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Seat belt recommendation Vote_lcapSeat belt recommendation Voting_barSeat belt recommendation Vote_rcap
TBONE21
Execelon
scotearl
10 posters
scotearl
scotearl
Seat belt recommendation Empty
PostSubject: Seat belt recommendation   Seat belt recommendation Icon_minitimeSun Jun 02, 2013 10:12 pm
My Rhino has only the female ends of the seat belts. I'm not sure what the story is on that, but I want to be able to buckle up. Anybody here got a recommendation? I've done the usual eBay search and t looks like mostly four points, many by Crow. It seems you have to buy a cross bar for them to wrap around. Is that the way to go?
PostSubject: Re: Seat belt recommendation   Seat belt recommendation Icon_minitimeMon Jun 03, 2013 7:09 am
i have 4 points in mine. You dont have to buy a cross bar. You can bolt them down back where the seat base slides into. I would recommend 5 points and i may swap mine out for some 5 points at some time.
scotearl
scotearl
PostSubject: Re: Seat belt recommendation   Seat belt recommendation Icon_minitimeFri Jun 07, 2013 1:04 pm
Is one brand better than the other? What fabrication/modification is required to bolt them at the seat base?
Anybody here using the wrap around style with a bar? If so, got a bar recommendation?
PostSubject: Re: Seat belt recommendation   Seat belt recommendation Icon_minitimeFri Jun 07, 2013 1:42 pm
I like the Y-type harness. its easier to get in and out of...imo
Execelon
PostSubject: Re: Seat belt recommendation   Seat belt recommendation Icon_minitimeFri Jun 07, 2013 1:59 pm
I'd highly recommend a harness bar with out it if something happens all the pressure is on your shoulders and back..
I have a couple friends running the 3" pro armor and bling star 4 points in the H wrap around style, they seam to be very nice
I'm going with the much cheaper superatv harness's
PostSubject: Re: Seat belt recommendation   Seat belt recommendation Icon_minitimeFri Jun 07, 2013 2:09 pm
Look for the cam style also. The latch style can be a real pita. I've had both and will never go back to the latch ones. Plus if you take someone out that hasn't used the latch they can have trouble holding all the parts together.
http://www.trailbrightled.com
TBONE21
TBONE21
PostSubject: Re: Seat belt recommendation   Seat belt recommendation Icon_minitimeFri Jun 07, 2013 4:16 pm
I love the 5 point pro armor. The padding is awesome.
PostSubject: Re: Seat belt recommendation   Seat belt recommendation Icon_minitimeFri Jun 07, 2013 4:34 pm
ive never seen you go fast enough to need them..lmao
TBONE21
TBONE21
PostSubject: Re: Seat belt recommendation   Seat belt recommendation Icon_minitimeFri Jun 07, 2013 4:37 pm
That's because u go so slow and cannot see all the fast people passing u
PostSubject: Re: Seat belt recommendation   Seat belt recommendation Icon_minitimeFri Jun 07, 2013 5:11 pm
I love my Crow 5 point H-style 3" padded belts. On my stock cage I fabd bars to go behind each seat, they were welded onto the cage. I also welded eye bolts on it so I could use the clips on the belts. Also drilled and tapped the lower OEM mounts for the crow eye bolts. The sub belt also has the eye bolt that goes into the angle iron just below the seat latch. I prefer the clips instead of bolts or wrapping the belts. Much easier to remove belts and seats for maintenance and cleaning.
thekrust
thekrust
PostSubject: Re: Seat belt recommendation   Seat belt recommendation Icon_minitimeTue Jun 11, 2013 5:24 pm
I've got Simpson 4 points in mine with a harness bar that attaches to the stock upper belt mounts. Does not get in the way of tilting bed. More than enough for the average guy and they're comfortable to wear all day.
Rhino Russ
Rhino Russ
PostSubject: Re: Seat belt recommendation   Seat belt recommendation Icon_minitimeFri Jun 14, 2013 10:56 pm
I have the crow four point with the bar in my rhino I like them! I have the factory belts if your interested in them?
scotearl
scotearl
PostSubject: Re: Seat belt recommendation   Seat belt recommendation Icon_minitimeMon Jun 17, 2013 12:29 pm
I like the harness bar concept and am looking for a recommendation on which one and who to buy from.
I saw one on youtube from Rhinogiant - are they good to deal with?
PostSubject: Re: Seat belt recommendation   Seat belt recommendation Icon_minitimeMon Jun 17, 2013 1:13 pm
i think we got some stuff from them along time ago....
» Seat belt
» 08 stock seat belt harns complete setup.
» what belt to go with
» belt burning up.. need help
» 1st belt slip?
HOTRODRHINOFORUMS.COM :: Safety :: Seats and Belts-
