In total there are 64 users online :: 0 Registered, 0 Hidden and 64 Guests :: 1 Bot
14g or 16g weights Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
14g or 16g weights Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
14g or 16g weights Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
14g or 16g weights Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
14g or 16g weights Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
14g or 16g weights Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
14g or 16g weights Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
14g or 16g weights Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
14g or 16g weights Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
14g or 16g weights Vote_lcap14g or 16g weights Voting_bar14g or 16g weights Vote_rcap
 14g or 16g weights
CaptainEER
6 posters
CaptainEER
CaptainEER
14g or 16g weights Empty
PostSubject: 14g or 16g weights   14g or 16g weights Icon_minitimeSun Jun 09, 2013 7:48 pm
Just wanted to ask you all thats ran both how much diffrence there is between the two? Can you feel it much from seat of pants? I'm running orange spring now with 16s, heavy 27'' tires, full cab, cdi. Everything else stock.
Also probably be installing a cam for more low end. Will this change the clutch setup i have now?
PostSubject: Re: 14g or 16g weights   14g or 16g weights Icon_minitimeSun Jun 09, 2013 8:15 pm
You need 16's for your bike 14's will rev to quick.
PostSubject: Re: 14g or 16g weights   14g or 16g weights Icon_minitimeSun Jun 09, 2013 8:33 pm
Sorry I should have read your what size bike you had first someone else might answer this better.
PostSubject: Re: 14g or 16g weights   14g or 16g weights Icon_minitimeSun Jun 09, 2013 9:29 pm
I say 14's but it wouldn't be the first time I'm wrong. lol!
PostSubject: Re: 14g or 16g weights   14g or 16g weights Icon_minitimeSun Jun 09, 2013 10:53 pm
I've ran both and have similar set up to You. Yes You can feel and hear the difference.
It really comes down to a personal preference. Think of it like driving a manual transmission. The lighter the weight, the longer Your leaving it in a gear before You shift. with 14's compared to 16's You will rev higher which is great for take off, but it gives You higher cruising RPM's. I prefer the 16's on mine , but I have 26in tires. Your heavy 27in would make me lean toward the 14's, but then if You cam it, I think the 16's would be better.
PostSubject: Re: 14g or 16g weights   14g or 16g weights Icon_minitimeSun Jun 16, 2013 9:48 am
I have never run the 16's but james recommended the14's with my 27's it seems to keep me in the meat of the power band but does rev a little higher than stock, do you do a lot of hills or pullin through mud i'd say the lighter wt's would be better if runnin on the flats than probably the 16's but ask james to be sure
EddieMc
EddieMc
PostSubject: Re: 14g or 16g weights   14g or 16g weights Icon_minitimeSun Jun 16, 2013 5:52 pm
Try a mix of both... called 15s it should give u the best of both worlds
14g or 16g weights
» OD weights vs Roller weights vs slugged wet clutch
» secondary springs or weights
» Weights
» OD weights
» clutch weights
