In total there are 64 users online :: 0 Registered, 0 Hidden and 64 Guests :: 1 Bot
Weights  Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Weights  Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Weights  Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Weights  Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Weights  Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Weights  Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Weights  Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Weights  Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Weights  Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Weights  Vote_lcapWeights  Voting_barWeights  Vote_rcap
 Weights
Djbison
6 posters
Djbison
Djbison
Weights  Empty
PostSubject: Weights    Weights  Icon_minitimeSun Mar 31, 2013 9:35 pm
I'm just curious what would be the difference in 14gr weights an the 16gr ones like what changes between the two do I loose or gain bottom or top end??
Weights  Empty
PostSubject: Re: Weights    Weights  Icon_minitimeSun Mar 31, 2013 9:39 pm
x2
Weights  Empty
PostSubject: Re: Weights    Weights  Icon_minitimeSun Mar 31, 2013 9:41 pm
660 or 700
Weights  Empty
PostSubject: Re: Weights    Weights  Icon_minitimeSun Mar 31, 2013 9:47 pm
With 14gr, my RPM's came up a lot faster on take off, but with 16gr my cruising RPM's were lower. Lower weight will give You a higher running RPM if You are having a problem with it bogging.
Lighter weights is similar to driving a manual transmission and leaving it in a lower gear longer before shifting. Hope this helps
Djbison
Djbison
Weights  Empty
PostSubject: Re: Weights    Weights  Icon_minitimeSun Mar 31, 2013 10:16 pm
Yeh that helps a lot thanks! It's a 660 James u just sent me 16gr I have 14gr an I wasn't to sure if I liked the 14gr but I went on a good ride an I liked it a lot! I haven't been able to go on open cruise to see top end yet but I will try the 14gr first!!!
Weights  Empty
PostSubject: Re: Weights    Weights  Icon_minitimeSun Mar 31, 2013 10:18 pm
what larry said...lol
Djbison
Djbison
Weights  Empty
PostSubject: Re: Weights    Weights  Icon_minitimeSun Mar 31, 2013 10:21 pm
Lol I got to go for a good ride an I love your clutch set up way better bottom an the engine brake is sweeeet!!!
Weights  Empty
PostSubject: Re: Weights    Weights  Icon_minitimeSun Mar 31, 2013 10:23 pm
thanks!!
Junglerider
Junglerider
Weights  Empty
PostSubject: Re: Weights    Weights  Icon_minitimeSun Mar 31, 2013 11:00 pm
You can also alternate the 14's and 16's in the clutch to get an effective weight of 15g. Lot's of options to play with.
http://www.jungleatv.com
RiverRat
RiverRat
Weights  Empty
PostSubject: Re: Weights    Weights  Icon_minitimeSun Apr 07, 2013 8:44 pm
I'm not sure what weights I have. (Bought the rhino from someone who did the hot rod sheave) I think the number on the weight was 3015. What do I have?
Weights  Empty
Weights
» OD weights vs Roller weights vs slugged wet clutch
» secondary springs or weights
» 14g or 16g weights
» OD weights
» clutch weights
