| Aftermarket seat bases | |
toobad4u
Posts : 23 Join date : 2013-07-17 Age : 48 Location : Panama City, FL
| Subject: Aftermarket seat bases Thu Jul 25, 2013 5:39 pm | |
| I saw the other post about building some, but I am just interested in buying a set. I have my seats on order, so I figured I should get some of these on the way. If you have some can you give me some personal opinions of what you have? Would you buy them again or different brand? I will be building a cage once i get my seats in, and want to get the roof as low as possible. I will post some pics once I start the cage build. I came over from the rock crawling scene, so the cage shouldn't be too bad. Just have to come up with a design I like.
Thanks in advance, Stephen | |
Bumpers
| Subject: Re: Aftermarket seat bases Fri Jul 26, 2013 11:53 am | |
| I have sdr seat bases but it wouldn't be hard to build a set if you have any fab skills and access to a plasma table or somthing | |
| Subject: Re: Aftermarket seat bases Fri Jul 26, 2013 2:25 pm | |
| i. wanna build some too, can someone with some take a couple pics and maybe post the dimensions and steel...? or is their a thread on this type of thing? | |
toobad4u
| Subject: Re: Aftermarket seat bases Sun Jul 28, 2013 10:05 pm | |
| I ordered a set last night. I'll post some good pics once they arrive. I have the plasma but don't feel like trying to re-invent the wheel. Seems there is only basically 1 way to build them. Figuring $30-$40 in materials, and 3-4 hours in labor it is almost a break even deal to just buy them. That tedious stuff really sucks to me.
Stephen | |
| Subject: Re: Aftermarket seat bases Mon Jul 29, 2013 12:38 am | |
| you got a link of where you got them? | |
| Subject: Re: Aftermarket seat bases Mon Jul 29, 2013 6:49 am | |
| Subject: Re: Aftermarket seat bases Mon Jul 29, 2013 9:59 am | |
| thanks teddy, will the base work with a stock seat? | |
| Subject: Re: Aftermarket seat bases Mon Jul 29, 2013 12:21 pm | |
| I'm not a %100 sure but yes I thank they will. | |
toobad4u
| Subject: Re: Aftermarket seat bases Tue Jul 30, 2013 3:57 pm | |
| I ordered mine through Str8up Motorsports. Hopwfully they will be here some time next week. The ones I ordered say that they only work with aftermarket seats, but I'll take some pics and measurements once I get them in my hands.
Stephen | |
Snorider
| Subject: Re: Aftermarket seat bases Tue Aug 27, 2013 9:04 pm | |
| any update on the seat bases? | |
toobad4u
| Subject: Re: Aftermarket seat bases Wed Aug 28, 2013 1:25 pm | |
| Yeah, the bases came in. The seats I ordered don't bolt to them correctly since the Corbeau seats I got are designed for stock mounting locations. The bases seem to be setup for a more universal type aftermarket seat. I bolted the Corbeaus to the stock bases for now. You sit at the same height, but they are way more comfortable. They also have a little more lean back to them. They are close to the bed. The only main gripe I have about the Corbeau seats is that they stick outside of the roll bar about 1-1 1/2". Some of the trails around here might be close to hitting them. I'll just have to be careful. Im going to keep the bases since they will bolt to a PRP or other aftermarket seat in case I decide these seats are too wide.
Stephen | |
Snorider
| Subject: Re: Aftermarket seat bases Fri Aug 30, 2013 6:25 pm | |
| Good to know about the corbeau seats. thanks for that info.
did you go low back or high back?
and depending which one you got do you wish you had gotten the other? | |
toobad4u
| Subject: Re: Aftermarket seat bases Mon Sep 02, 2013 10:17 pm | |
| I got the high back for a Rhino. I like the high back part, but wished I would have gotten a different brand of seat. They are nice but a little too wide. I had to bend the outside seatbelt bracket out quite a bit so they would fit.
Stephen | |
Snorider
| Subject: Re: Aftermarket seat bases Mon Sep 02, 2013 11:10 pm | |
| Ok I was thinking about the mastercraft seats but wasn't sure about High back or low back. Plus I was also thinking about the lower seat bases to get more head clearance from my gun rack. | |
| Subject: Re: Aftermarket seat bases | |
