| Lower seat bases. | |
+2Mrs. Hot Rod Workhorserhino 6 posters |
Workhorserhino
| Subject: Lower seat bases. Sat Apr 27, 2013 10:17 pm | |
| I would like to lower the seats some. I would like to make them myself. But need some ideas. If anybody has them or made their own, post some pics please. The seat latch post also. Cause whatever the seat lowers the post will have to lower the same I think. Might be next months project. | |
Mrs. Hot Rod Admin
| Subject: Re: Lower seat bases. Mon Apr 29, 2013 11:11 pm | |
| We ordered some but James never installed them & we ended up selling them to T.Rhino .... maybe he will chime in ... | |
| Subject: Re: Lower seat bases. Tue Apr 30, 2013 3:47 pm | |
| They are easy to make. The tricky part is to make them so they don't rattle! Keep in mind they are flat, the stock seat base is tilted back. So your seats will lean forward some. Also most bases that lower your seats need to move the seat outwards to clear the engine cover. I have had 2 sets and don't like them.My new LSR cage is 4" lower than stock so I'm currently using the stock bases on my BS Sand seats. Even with that setup I have spacers to lean the seat back a little. That's a whole different thread some day! | |
| Subject: Re: Lower seat bases. Tue Apr 30, 2013 4:05 pm | |
| - Mrs. Hot Rod wrote:
- We ordered some but James never installed them & we ended up selling them to T.Rhino .... maybe he will chime in ...
I will post some pics tonight. | |
Workhorserhino
| Subject: Re: Lower seat bases. Tue Apr 30, 2013 5:06 pm | |
| The pics would be great, thanks. My seat can lean forward more. I was hoping for that. Stock is back a little to much for my back. Esspecially if I'm into for a long time. I was thinking for the back to bend a steel rod, make it look like the factory outline. Then grind to fit snug under bar or put rubber hose on it and use smaller diameter rod. | |
| Subject: Re: Lower seat bases. Tue Apr 30, 2013 7:01 pm | |
Last edited by onebuilder on Tue Apr 30, 2013 7:10 pm; edited 2 times in total | |
| Subject: Re: Lower seat bases. Tue Apr 30, 2013 7:08 pm | |
| Subject: Re: Lower seat bases. Wed May 01, 2013 6:46 am | |
Workhorserhino
| Subject: Re: Lower seat bases. Fri May 03, 2013 10:18 pm | |
| Thanks for the pics and suggestions everybody. I took a half day off yesterday. today after work finished roughing it out. This is what I ended up with. | |
Workhorserhino
| Subject: Re: Lower seat bases. Fri May 03, 2013 10:21 pm | |
| Pic of the frame bolted to seat. | |
Workhorserhino
| Subject: Re: Lower seat bases. Fri May 03, 2013 10:26 pm | |
| I wanted to use to original latch, because its easy and didn't have to buy anything else. So this is what I came up with. | |
Workhorserhino
| Subject: Re: Lower seat bases. Fri May 03, 2013 10:28 pm | |
| Modifications needed on front to make latch work. | |
Workhorserhino
| Subject: Re: Lower seat bases. Fri May 03, 2013 10:31 pm | |
| Seat installed and latched in place. | |
| Subject: Re: Lower seat bases. Fri May 03, 2013 10:35 pm | |
| Looks better than factory!!! Now all ya got to do is pull straight out it looks like instead of up and out. Very nice work! | |
Workhorserhino
| Subject: Re: Lower seat bases. Fri May 03, 2013 10:48 pm | |
Workhorserhino
| Subject: Re: Lower seat bases. Sat May 04, 2013 11:55 am | |
| looks good to me | |
| Subject: Re: Lower seat bases. | |
