| Rhino REEKS like gas. | |
+5REDRHINO64 08Rhino450SE 123.bert0621 ASPENDELLROVER Tunderslimer 9 posters |
Tunderslimer
| Subject: Re: Rhino REEKS like gas. Thu Aug 08, 2013 12:29 am | |
| thanks for all the replies guys! it's hot up here now, closing in on 30C most days. my gas cap is billet, and seals up well. i haven't had a chance to pull it apart yet - but i'm suspecting, like most of you, it is in the carb/fuel line area. i'll let you know what I find once I tear into it. sounds like we are going riding sunday, and it's gonna be hot. gotta fix this.
i find the smell gives me heartburn. could be the three thousand beers and the bumps too though. | |
Tunderslimer
| Subject: Re: Rhino REEKS like gas. Thu Aug 08, 2013 12:31 am | |
| - 08Rhino450SE wrote:
- prolly just fuel backed into the air filter (reversion)
how does one fix this? actually before any assumptions I'll tear it up and let you know what I find.
like, it REEEEEEKS. like $$$$ going into the air. is it a stock carb, cam, valves and exhaust? yep stock everything. wasn't when i bought it, i rejetted, removed muzzy's, and installed new stock airbox. | |
| Subject: Re: Rhino REEKS like gas. Thu Aug 08, 2013 9:19 am | |
| does the air filter smell fuel-soaked?
do you know if there was a cam installed when you bought it? if so the cam might have too much overlap for a stock exhaust. a stock exhaust with a high overlap cam would not allow proper scavenging of the cylinder exhaust gasses, causing them to pulse back into your intake and cause standoff at the carb/air cleaner.
for now i would clean out the air filter and try to get as much air into the cylinder as possible. if the air cleaner is fuel-soaked you'll know that it's happening. if not then something else is going on. | |
| Subject: Re: Rhino REEKS like gas. Thu Aug 08, 2013 10:51 am | |
| Make sure after you fix the fuel problem,change your engine oil. | |
Tunderslimer
| Subject: Re: Rhino REEKS like gas. Fri Aug 09, 2013 2:41 am | |
- does the air filter smell fuel-soaked?
for now i would clean out the air filter and try to get as much air into the cylinder as possible. if the air cleaner is fuel-soaked you'll know that it's happening. if not then something else is going on. it's a possibility. still haven't had a chance to check it, but this thing was macked out as far as it could be. an aftermarket cam wouldn't surprise me... we had it up to 92 km/h with stock exhaust, jetting and air box. would a rhino on 27's, made stock aside from a CDI and JBS sheave, do 92 km/h (57 mph)? i do feel pressure at the air intake on the center console when it's running, like air both going in and out. it goes like a raped ape and runs awesome. just stinks. | |
Tunderslimer
| Subject: Re: Rhino REEKS like gas. Fri Aug 09, 2013 2:42 am | |
| - 123.bert0621 wrote:
- Make sure after you fix the fuel problem,change your engine oil.
absolutely, thanks for the reminder | |
Tunderslimer
| Subject: Re: Rhino REEKS like gas. Thu Aug 15, 2013 9:21 pm | |
| Found the problem boys (and girl!)
Shitty OEM hose clamp at the carb end of the fuel line and a leaky float bowl gasket. i re-jetted not that long ago and should have replaced the gasket. ah well, cheap fix luckily. | |
| Subject: Re: Rhino REEKS like gas. Thu Aug 15, 2013 9:23 pm | |
| Real good news for you,I guess that means your off to Harrison again. | |
Tunderslimer
| Subject: Re: Rhino REEKS like gas. Thu Aug 15, 2013 9:29 pm | |
- Real good news for you,I guess that means your off to Harrison again.
not this weekend but next!!!! i'll post a video compilation of both the week we were away plus the next weekend... i'm gonna go HARD next time out!!! haha | |
| Subject: Re: Rhino REEKS like gas. Thu Aug 15, 2013 9:31 pm | |
| Have a great time | |
Tunderslimer
| Subject: Re: Rhino REEKS like gas. Thu Aug 15, 2013 9:38 pm | |
| speaking of Harrison, they told me not to ride on the beach. FINE, I'LL RIDE IN THE LAKE. | |
Tunderslimer
| Subject: Re: Rhino REEKS like gas. Thu Aug 15, 2013 9:41 pm | |
| found a sweet 200 ft sandbar... damn dog wouldn't let me out of the water. | |
| Subject: Re: Rhino REEKS like gas. Thu Aug 15, 2013 10:41 pm | |
| Thats funny,looks almost tropical. | |
| Subject: Re: Rhino REEKS like gas. | |
