| Teryx shock install | |
+7thePayne vbryan00 123.bert0621 09-rhino700 REDRHINO64 ASPENDELLROVER rhinopolice 11 posters |
rhinopolice
Posts : 12 Join date : 2013-09-01 Location : New Orleans
| Subject: Teryx shock install Sun Sep 01, 2013 11:35 am | |
| Hey guys, Well since I put the rear cage on, I have noticed that she is a smidge lower in the rear. So, I bought some Teryx shocks and tackled the install. The fronts are cake. Direct replacement. Gave me about 2" in lift. Then the rears........ My uncle owns a machine shop, so I had him lathe down the bushings for the bottom: He milled down a little too much, so I shimmed it over with a washer. No Worries. I took the bolt head and made it into a carriage bolt. I also flattened one part to be able to tighten it down. I also ground down a bit of the shock housing to give me more clearance to the axle. It wasn't much though. So, the outcome..... 2" lift in front 1.75ish " lift in rear Ride is definitely stiffer, body roll is significantly decreased. I like it though. Cheap mod and worked well. Just wanted to share. | |
| Subject: Re: Teryx shock install Sun Sep 01, 2013 1:17 pm | |
| Subject: Re: Teryx shock install Sun Sep 01, 2013 3:27 pm | |
| Subject: Re: Teryx shock install Sun Sep 01, 2013 8:42 pm | |
| just did mine too, it's great give them 100 miles they will loosen up :-) | |
| Subject: Re: Teryx shock install Sun Sep 01, 2013 11:55 pm | |
rhinopolice
| Subject: Re: Teryx shock install Mon Sep 02, 2013 12:56 am | |
vbryan00
Posts : 41 Join date : 2013-11-04
| Subject: Re: Teryx shock install Mon Nov 04, 2013 1:40 pm | |
| Just want to ask why the rears have to be run upside down? I am looking a getting a set but am curious why they cannot be run conventional position. So I am just doing my research. | |
| Subject: Re: Teryx shock install Mon Nov 04, 2013 2:24 pm | |
vbryan00
| Subject: Re: Teryx shock install Mon Nov 04, 2013 2:39 pm | |
| Ok, well I just committed to a brand new set of takeoffs so here goes nothing. | |
| Subject: Re: Teryx shock install Mon Nov 04, 2013 2:40 pm | |
| take your time and I am sure if you don't find the information you need on here the guys will be happy to call and talk to you about it they are a A+++ group of guys!! | |
vbryan00
| Subject: Re: Teryx shock install Mon Nov 04, 2013 3:45 pm | |
| Not worried about the fab work worked in a machine shop for several years so I learned quite alot | |
| Subject: Re: Teryx shock install Mon Nov 04, 2013 7:54 pm | |
| Great upgrade for the price. To answer your question, they can't be installed right side up because the lower shock mount in the A-arm is to thin for the shock body. There really isn't a way to mount them right side up without prefabricating new mounts. | |
vbryan00
| Subject: Re: Teryx shock install Mon Nov 04, 2013 8:43 pm | |
| Thanks that will give me something to look into. If I'm going to havt to make modifications to the shock might be easier to fan new mounts | |
| Subject: Re: Teryx shock install Tue Nov 05, 2013 9:53 am | |
| When you first install them they are SUPER stiff. You're going to be riding a pogo stick. Give it about 100-200 miles and you'll love them. | |
vbryan00
| Subject: Re: Teryx shock install Tue Nov 05, 2013 10:28 am | |
| We don't get o go out on the trails as much as we would like but since I use mine to work around the house mainly hauling wood. hopefully they will break in fairly quick.
| Subject: Re: Teryx shock install Tue Nov 05, 2013 12:32 pm | |
| What adjustments do the teryx shocks have. Do they have rebound and compression. | |
vbryan00
| Subject: Re: Teryx shock install Wed Nov 06, 2013 2:06 pm | |
| has anyone experienced any axle or CV joint problems with Teryx shocks | |
vbryan00
| Subject: Re: Teryx shock install Thu Nov 07, 2013 10:29 am | |
| Well I put the fronts on last night and it really is stiff. You would not think that with only about 200lbs diff in weight between the Teryx and Rhino it would be so extreme. The set of shocks I bought only had resi rears, front are conventional. Will work on the rears on my day off. | |
vbryan00
| Subject: Re: Teryx shock install Fri Nov 08, 2013 9:49 pm | |
| Well I have been fighting with the rears today and I can not get the pass rear to work without tearing the outer boot off. The suspension is fully extended with the shocks on and the best solution I have come up with is to fab new upper mounts. Any Ideas? The right rear axle is a gorilla, might be the problem? | |
UnderDawg
| Subject: Re: Teryx shock install Sat Nov 09, 2013 1:11 am | |
| can ya post up some pics for us to see the problem? | |
vbryan00
| Subject: Re: Teryx shock install Sat Nov 09, 2013 8:47 am | |
UnderDawg
| Subject: Re: Teryx shock install Sat Nov 09, 2013 10:57 am | |
| I seem to remember reading of others having problems running gorilla axles with these shocks.... but you might have some other issue like a bent A-arm. | |
| Subject: Re: Teryx shock install Sat Nov 09, 2013 12:13 pm | |
| The easiest solution is limit straps. They only cost about $30 and will limit the extension of the shocks so they can't extend to the point where it bottoms out on the mount. I think Gorilla axles are thicker than stock axles which is why you are hitting...but that's just an assumption. | |
vbryan00
| Subject: Re: Teryx shock install Sat Nov 09, 2013 1:19 pm | |
| Well I have too much to do today so back on with the blown shocks till I get time to sort it out. Thanks for the feedback
clembone
Posts : 24 Join date : 2013-04-15
| Subject: Re: Teryx shock install Tue Nov 12, 2013 2:31 pm | |
| What are the benifits of these shocks? I am interested in upgrading my suspension for a better smoother ride? Do these make it smoother and handle better or they just more heavy duty. thanks for the info. | |
| Subject: Re: Teryx shock install | |
