In total there are 27 users online :: 0 Registered, 0 Hidden and 27 Guests
Engine braking??? Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Engine braking??? Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Engine braking??? Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Engine braking??? Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Engine braking??? Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Engine braking??? Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Engine braking??? Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Engine braking??? Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Engine braking??? Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Engine braking??? Vote_lcapEngine braking??? Voting_barEngine braking??? Vote_rcap
 Engine braking???
Djbison
6 posters
Djbison
Djbison
Engine braking??? Empty
PostSubject: Engine braking???   Engine braking??? Icon_minitimeTue Oct 15, 2013 1:35 am
Took my Rhinonout for a turkey ride this weekend I was going down some hills an my engine brake wa working good then it would almost feel like it was going into neutral why is that? Is my wet clutch wore out?
PostSubject: Re: Engine braking???   Engine braking??? Icon_minitimeTue Oct 15, 2013 2:19 am
I think James said it is the one way bearing that does this.  Mine has been acting up from time to time.  Doesn't bother me a whole lot because I am used to driving a rzr.
PostSubject: Re: Engine braking???   Engine braking??? Icon_minitimeTue Oct 15, 2013 7:25 am
One way bearing.
PostSubject: Re: Engine braking???   Engine braking??? Icon_minitimeTue Oct 15, 2013 8:23 am
x3 on ur oneway being shot .  Dang Hump ,  yours doesn't have very many miles on it , to be doing that ?!?
Djbison
Djbison
PostSubject: Re: Engine braking???   Engine braking??? Icon_minitimeTue Oct 15, 2013 9:59 am
Ok cool thanks guys I have a new one to out in when I change my wet clutch an slug it!!!!
PostSubject: Re: Engine braking???   Engine braking??? Icon_minitimeTue Oct 15, 2013 10:23 am
be sure to check the wet clutch drum also, that it doesn't have groves a little wear there goes a long way toward slipping just my 2 cents on it
PostSubject: Re: Engine braking???   Engine braking??? Icon_minitimeTue Oct 15, 2013 11:18 am
one way...seen a few on the newer ones going out quicker than they should
Djbison
Djbison
PostSubject: Re: Engine braking???   Engine braking??? Icon_minitimeTue Oct 15, 2013 12:03 pm
I have a new drum an wet clutch to change it out just have to find the time to do it! Thanks guys!!
PostSubject: Re: Engine braking???   Engine braking??? Icon_minitimeTue Oct 15, 2013 2:29 pm
DJ  sounds like you ready   cheers
Engine braking???
» Engine Braking Dis-Engages At 8MPH During Deceleration
» pulling out 700 engine
» side engine fan
» Engine Oil Cooler
» Engine pics
