| How to add weight to wet clutch | |
+1709-rhino700 chuddly txgrown1404 Dizzledog1 ASPENDELLROVER scottwv Workhorserhino foyota86 Deuces wild CUSTOMIZEDRHINO13 hymarker REDRHINO64 rhino727 DEZLFREK madmax 1 WV Hot Rod Rhino Stuntmanmike 21 posters |
| Subject: How to add weight to wet clutch Sun Mar 17, 2013 10:50 pm | |
| Subject: Re: How to add weight to wet clutch Mon Mar 18, 2013 9:20 am | |
| Subject: Re: How to add weight to wet clutch Fri Mar 22, 2013 4:04 pm | |
DEZLFREK
Posts : 52 Join date : 2013-03-15 Age : 52 Location : sonoma ca
| Subject: Re: How to add weight to wet clutch Fri Mar 22, 2013 10:13 pm | |
| yes and works really well..
thanks mike. | |
| Subject: Re: How to add weight to wet clutch Mon Mar 25, 2013 9:16 pm | |
| great info cant wait to get my new wet clutch an add weight | |
| Subject: Re: How to add weight to wet clutch Mon Mar 25, 2013 9:31 pm | |
| James,you get yours done yet?? | |
hymarker
| Subject: Re: How to add weight to wet clutch Tue Mar 26, 2013 12:34 am | |
| I may have to give this a try! | |
| Subject: Re: How to add weight to wet clutch Thu Mar 28, 2013 7:19 pm | |
| Thanks, I am thinking about doing this too. | |
DEZLFREK
| Subject: Re: How to add weight to wet clutch Thu Mar 28, 2013 10:10 pm | |
| you wont regret it.. makes a great addition to the clutch system.. | |
| Subject: Re: How to add weight to wet clutch Thu Mar 28, 2013 10:33 pm | |
| I might add some weight to mine also..but im gonna have to wait and see what james has to say about it!!..trial and error!!! | |
Deuces wild
| Subject: Re: How to add weight to wet clutch Thu Mar 28, 2013 11:15 pm | |
| can we get an extension on the 15 days?lol | |
| Subject: Re: How to add weight to wet clutch Sat Apr 20, 2013 6:54 pm | |
| Any videos on getting to the clutch, about to tear into sheaves? Also any gaskets or anything that can't be reused, I don't want to tear into Rhino and be waiting on something simple. | |
Workhorserhino
| Subject: Re: How to add weight to wet clutch Sat Apr 20, 2013 7:35 pm | |
| Nice job on the pics. Seems really simple to do, other than getting clutch out. Looks like you used an old wheel weight in the pic. What a cheap upgrade. | |
| Subject: Re: How to add weight to wet clutch Sat Apr 20, 2013 10:45 pm | |
| You will need a gasket for the drum housing, and you will need to drain your oil. So 3 qts of oil and filter. And any kind of lead will work, rim leads, fishing leads. they are very cheap. If you need more info on how to do it feel free to call me at 850 259-1166, Mike. | |
| Subject: Re: How to add weight to wet clutch Sat Apr 20, 2013 10:51 pm | |
| from the looks of that video,they work very good!! | |
| Subject: Re: How to add weight to wet clutch Sun Apr 21, 2013 9:35 am | |
| how bout a vid on sluggin the wet clutch for us dummies james, kill 2 birds with 1 stone, wet clutch& slugging same vid | |
| Subject: Re: How to add weight to wet clutch Sun Apr 21, 2013 10:20 am | |
| did mine the other day , used #8 bird shot an reloader scales to measure out exact amount for each hole got so annul about it that I was cutting shot down to get wright , but very easy job an super cheap now just need to finish the rest of project an ride | |
| Subject: Re: How to add weight to wet clutch Sun Apr 21, 2013 12:04 pm | |
| Subject: Re: How to add weight to wet clutch Mon Apr 22, 2013 8:47 am | |
| Ok Mike , I've been reading about this for a while now...so I have a couple of questions. How long have you ran yours "slugged" ; and , is there any long-term downside to doing this ?? I replaced my w.c. prob 6 months ago...I don't want to do any type of mod that would cause me to havta drop another $400 . | |
| Subject: Re: How to add weight to wet clutch Thu May 02, 2013 10:22 pm | |
| Subject: Re: How to add weight to wet clutch Thu May 02, 2013 10:47 pm | |
| I slugged my first clutch in 06 and the wet clutch lasted over 2 years and that's when i was mud racing it. I replaced the wet clutch when i went with the stroker crank in 09 and it looked like normal wear, No burn marks or scoring of the drum. I replaced it agian 5 months ago and the drum is still original with no deep marks and normal wear on the clutch. So in conclusion I have not seen anything negative because of adding weight. But it does last longer because it doesnt slip as much as stock. And the same goes for all the customer bike's Ive done. IT is all good in my experiance. | |
| Subject: Re: How to add weight to wet clutch Thu May 02, 2013 10:52 pm | |
| we need a "how to slug your clutch for dummies" thread... | |
| Subject: Re: How to add weight to wet clutch Fri May 03, 2013 7:36 am | |
| - Stuntmanmike wrote:
- I slugged my first clutch in 06 and the wet clutch lasted over 2 years and that's when i was mud racing it. I replaced the wet clutch when i went with the stroker crank in 09 and it looked like normal wear, No burn marks or scoring of the drum. I replaced it agian 5 months ago and the drum is still original with no deep marks and normal wear on the clutch. So in conclusion I have not seen anything negative because of adding weight. But it does last longer because it doesnt slip as much as stock. And the same goes for all the customer bike's Ive done. IT is all good in my experiance.
Thanks Mike , that's what I was wondering. | |
| Subject: Re: How to add weight to wet clutch Fri May 03, 2013 10:29 am | |
| good info Mike I know your tread on rf got me right threw the mod an made it easy for me keep sharing these mod tips it sure helps | |
Dizzledog1
| Subject: Re: How to add weight to wet clutch Fri May 03, 2013 10:38 am | |
| Just slugged mine yesterday. Took test drive and wow what a difference! Did it all in about 1 hr 1/2. Not to bad of a job. Got mine from Kms performance. For 50 $ with new gasket. | |
| Subject: Re: How to add weight to wet clutch | |
