| diff brace | |
+12Firefighter REDRHINO64 ASPENDELLROVER rhino727 Hump ChrisH Kenny G onebuilder banchee6 madmax 1 Jet bonez 16 posters |
| Subject: Re: diff brace Fri Apr 26, 2013 5:18 pm | |
| Subject: Re: diff brace Fri Apr 26, 2013 5:21 pm | |
| - Firefighter wrote:
- I may just build one !
If you do, make the diff mounting tabs like the CRB, NOT like the UTV inc ones. I've seen those sheer off! | |
| Subject: Re: diff brace Fri Apr 26, 2013 7:32 pm | |
| rear looks fairly easy to fab any pics on one for the front | |
| Subject: Re: diff brace Fri Apr 26, 2013 7:49 pm | |
| I don't know of anyone using a front. | |
| Subject: Re: diff brace Fri Apr 26, 2013 8:06 pm | |
| I guess i got the last crb brace.....sorry guys!! | |
| Subject: Re: diff brace Fri Apr 26, 2013 8:07 pm | |
| I have a piece of angle iron I was going to use for the part on the frame, but the square tube for the hitch goes all the way through the frame, sticking out about a quarter inch on the back side. If I use angle (for the part that bolts to the frame), It will have to be like 2.5 or 3in to go over where the hitch comes through. Best I can tell from the pics, the factory ones are a straight piece of steele with just a little angle on them. What do You guys think ? | |
| Subject: Re: diff brace Fri Apr 26, 2013 8:13 pm | |
| You could just notch out the angle iron, then fab up the 2 pieces that bolt to the dif and weld them on. | |
| Subject: Re: diff brace Sun Apr 28, 2013 11:18 am | |
| I made two separate braces out of billet aluminum. A little cutting, shaping and bending then drilling through the hitch cross brace to bolt it up solid! Had to use 3 washers as shims to get the proper clearance on the right hand brace. Redneck ingenuity! [img] [/img] [img] [/img] [img] [/img] | |
| Subject: Re: diff brace Sun Apr 28, 2013 9:26 pm | |
| Now that is something I could do ! I guess it has held up well ? | |
| Subject: Re: diff brace Sun Apr 28, 2013 9:44 pm | |
soarkrebel
| Subject: Re: diff brace Fri May 03, 2013 8:39 am | |
soarkrebel
| Subject: Re: diff brace Fri May 03, 2013 8:41 am | |
| I like this one........ | |
| Subject: Re: diff brace Fri May 03, 2013 9:31 am | |
| I seen that red one but it only connects on one side and was thinking the diff might still twist.
I ended up ordering one from BRP. Expensive, but I will have some "peace of mind" that the diff will not move. It looks just like the one in the pic above. | |
| Subject: Re: diff brace Fri May 03, 2013 10:16 am | |
| I like the one in pic looks fairly simple to build , think that's the one I will go with | |
| Subject: Re: diff brace Fri May 03, 2013 10:55 am | |
| made one like the red one in the pic,not much room with the Montana jacks rear winch mount figured one is better than none, went back an torqued and loc tited the bolts also | |
| Subject: Re: diff brace Fri May 03, 2013 11:05 am | |
| Gitter Done Mick !!! HAHA
Glad You said that, I will loctite mine when I put it on ! | |
| Subject: Re: diff brace Fri May 03, 2013 12:56 pm | |
| yea man you cant beat Loctite for hold things together | |
DHILL
Posts : 19 Join date : 2013-03-27 Location : Arkansas
| Subject: Re: diff brace Fri Aug 02, 2013 4:17 pm | |
| I did some searching around and made a few calls and wanted to pass on some info. I got ahold of Angela at CRB Alumifab about the rear diff brace they sell. She said their website is down and can't accept orders from it. She took my order over the phone. She also said their bracket can be ordered through black rhino performance because CRB makes the braces for brp. CRB sells the brace for $45 plus $10 for shipping. | |
| Subject: Re: diff brace Fri Aug 02, 2013 4:38 pm | |
| Thats good information,thanks.CRP is BRP and BRP is CRP in disguise | |
| Subject: Re: diff brace | |
| diff brace | |
