In total there are 21 users online :: 0 Registered, 0 Hidden and 21 Guests :: 2 Bots
Installed JBS Sheave - Need Help - Page 3 Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Installed JBS Sheave - Need Help - Page 3 Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Installed JBS Sheave - Need Help - Page 3 Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Installed JBS Sheave - Need Help - Page 3 Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Installed JBS Sheave - Need Help - Page 3 Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Installed JBS Sheave - Need Help - Page 3 Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Installed JBS Sheave - Need Help - Page 3 Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Installed JBS Sheave - Need Help - Page 3 Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Installed JBS Sheave - Need Help - Page 3 Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Installed JBS Sheave - Need Help - Page 3 Vote_lcapInstalled JBS Sheave - Need Help - Page 3 Voting_barInstalled JBS Sheave - Need Help - Page 3 Vote_rcap
m1n1ster
varmint10
RHINOMOON
Junglerider
defstar
21 posters
Go to page : Previous  1, 2, 3, 4  Next
Installed JBS Sheave - Need Help - Page 3 Empty
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeTue Jul 09, 2013 10:18 pm
ASPENDELL ROVER wrote:
phewww, you know after a long hike, this bike kicks ass! All I know is with JBS set up and advice, its a blast to drive. I can't imagine how fun it will be with an engine...lol
 u got my attention at hiking  lol! Dancing Banana Dancing Banana Dancing Banana
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeTue Jul 09, 2013 11:52 pm
u have guys hike in the hood of MD?...lol! been to Baltimore 1 time and there were more "ethnic's" than I have seen in my life, I was scared.Reneck  I stood out like a sore thumb. Don't think they liked my Carhartt and Copenhagen Reneck ..lmao
defstar
defstar
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeMon Jul 15, 2013 9:13 am
Alright guys...I had a chance to test out the Rhino again this weekend after putting the stock spring back on...things improved a little but still not where it should be imo...
Going from 40 to 49 is a little smoother now...but the slight stalling (like the rev limiter kicking in) is still there...though not as bad as it was before...and in a drag race from 0 to 40 my brother's stock Rhino is still winning by half a link...on the hill climb the low end did seem a little better but again not by much compared to the stock Rhino...from what everyone has said about the JBS sheave I think I should be getting far better results...
Now what do I do?...I hate to pull the wet clutch as I can't see this being the problem...my bike has 365 miles on the od and 65 hours on the time...still way too early for the wet clutch to be worn out under normal conditions...
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeMon Jul 15, 2013 9:19 am
18gr right?
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeMon Jul 15, 2013 10:08 am
 my bros all hike in western md . i'm 3 hrs from balt. never go there I like the quiet of the woods in the western part of the state Reneck  we all wear flannel and jeans , tee's hats and boots, Dancing Banana
defstar
defstar
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeMon Jul 15, 2013 11:36 am
WV Hot Rod Rhino wrote:
18gr right?
 Yes sir...18gr...and I held the cam plate tight the whole time installing to prevent weights from flipping...I also cleaned both sheave faces (pri & sec) really well with rubbing alcohol after install...so I don't think it's grease on the belt... scratch
defstar
defstar
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeWed Jul 17, 2013 9:51 am
James...does it sound like the results I'm getting now are correct?...is the increased low end there (ie why the stock rhino is ahead in the drag race because I'm geared a little lower) but I'm just unable to tell the difference under normal riding conditions?...most people make it out to be a night and day difference with the JBS sheave but I can't tell anything just driving around...I just want to make sure my sheave is machined correctly and is giving the correct results...
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeWed Jul 17, 2013 9:57 am
it shouldnt be still hitting the limiter while accelerating..a stock bike should not outrun you...
defstar
defstar
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeWed Jul 17, 2013 4:14 pm
Yes sir...like I said before 0 to 40 is smooth...only from 40 to 49 it feels like it's hitting a little...and again the lower end (JBS sheave w/18g weights and stock spring) feels about the same as stock...if anything just a tad lower but no "wow" difference...what should I try or do next?...
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeWed Jul 17, 2013 5:18 pm
what oil you running
defstar
defstar
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeWed Jul 17, 2013 5:25 pm
 I know it's Yamaha oil put in at the dealer...the bike was serviced right before I purchased it from the original owner...I can check the service ticket and see if it has the oil weight listed when I get home this evening...
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeWed Jul 17, 2013 6:00 pm
your gonna have to check the wet clutch just to eliminate that..what size tires are on it
defstar
defstar
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeWed Jul 17, 2013 7:04 pm
The oil on the invoice was "10W-40 MC Oil Drum" and they also replaced the spark plug...I'm running stock tires...is it possible the wet clutch is going bad with only 365 miles and 65 hours?...the original owner used this machine on his farm only...hauling feed to his cattle...no mudding or trail riding...
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeWed Jul 17, 2013 7:10 pm
If everything else is ok with the CVT sheaves, which it sounds like it is, then checking the wet clutch would be worth your time. Stranger things have happened. Seems like I remember a thread over on Highlifter where a guy bought a low-hours Rhino only to find out that the wet clutch was smoked.
I am sorry you are having issues. Hang in there man!
defstar
defstar
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeWed Jul 17, 2013 7:22 pm
 Thanks Chris!...I'll admit all of this is wearing a little heavy on me...I went with the Rhino after reading about so many people saying the JBS sheave does great things for it...now I'm hitting this wall and I'm left scratch ...but yeah something is going down this weekend...I'm going to pull everything back apart and before going into the wet clutch my brother and I may swap primary sheaves...I'll see how his machine does with the JBS and mine with his factory...if I in turn beat him in the drag race this time then there is a sheave problem...if his machine does even better then I'll know for sure it's my bike and my next step will be checking the wet clutch...
The sheave swap just seems like a faster check on things and may keep me from having to go into the wet clutch...if I do check the wet clutch is there any kind of gasket I'll need to buy/replace?...or is it just a matter of draining the oil and pulling the cover?...
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeWed Jul 17, 2013 7:32 pm
if the preveous owner did a lot of hauling or lugging in high range good chance it could be in the wet clutch, my sheave and spring did make the WOW factor yours should also
defstar
defstar
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeWed Jul 17, 2013 9:29 pm
Thanks madmax 1...that "WOW" factor is what I need right now...without it I can't see the point of installing my new 28" Outlaws!...Also when I check the wet clutch...do I need to go back with Yamaha motor oil or can I use Castrol?...and if I can use Castrol do I stick with 10-40 or can I go with 20-50?...I ask about 20-50 because we used that in our Honda's to combat the Texas heat...
sugarbear
sugarbear
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeWed Jul 17, 2013 11:06 pm
if you do end up in the wet clutch and it is the problem slug the new one. Then you really get the wow factor.
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeWed Jul 17, 2013 11:31 pm
sugarbear  you don't even have a rhino...... what  are you in the forum for..... fun?      Lol  jk buddy
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeThu Jul 18, 2013 11:01 am
i run 20-50 in the summer with no problems.
be sure to use a wet clutch compatible motorcycle oil!!!
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeThu Jul 18, 2013 11:26 pm
I run amsoil 4 stroke synthetic
defstar
defstar
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeSat Jul 20, 2013 5:56 pm
Alright guys...I just got back from further testing...I said before that my brothers bike was a 2012...it's actually a 2013 (sry about that) with less than 20 miles...we put the JBS sheave in it (with the 18g weights) and his factory primary sheave in mine...both of us are still using the factory secondary spring...
His bike did the exact same thing as mine did on the top end...from 40 to 49 it felt like the rev limiter was trying to kick in...also we drag raced again about a dozen times (switching bikes back and forth) and we either tied or he would edge me out by a nose from 0 to 40...
Just to remind everyone that before when the JBS was in my bike the top end rev limiter issue was there and when drag racing he was beating me by half a link...
I have not checked my wet clutch yet due to these results being so close together IMO with the JBS sheave in each of the bikes...
James...does this mean it's a sheave issue or do I still need to check my wet clutch?...is there a chance I was sent a 660 or 450 sheave by mistake or would that even make a difference?...
Please let me know what I need to do next...
Both our bikes are 700's and both are running stock tires...mine is a 2009 and his a 2013...my bike is also about 100 lbs heavier as I have a steel skid plate and some other protection parts...not sure if 100 lbs matters... scratch
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeSat Jul 20, 2013 6:14 pm
wow owl dude, thats a great top speed stock. my 08 would only hit 38 maybe 40 downhill with the wind. all I know is my jbs made a night and day diff. I wish I had an answer for ya
Dan700
Dan700
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeSun Jul 21, 2013 11:30 am
I have been following this forum for a couple days. I have a 2009 rhino stock. I bought a jbs sheave about a month or so back my rhino does the same thing from 40 to 49 it cuts out also. I haven't said anything yet because I haven't had a chance to take it apart and look at it. Just wanted to inform  you guys to. if I get a chance maybe I will take mine apart this week. 2009 rhino stock 18g od belt is in great condition
defstar
defstar
PostSubject: Re: Installed JBS Sheave - Need Help   Installed JBS Sheave - Need Help - Page 3 Icon_minitimeSun Jul 21, 2013 3:11 pm
 Thank you Dan for posting...I hate that you have the same problem but am glad I'm not in this boat alone...could it be just a bad batch of sheaves?...
Page 3 of 4Go to page : Previous  1, 2, 3, 4  Next
» JBS sheave and OD weights installed ! Couple ???s
» Got jbs sheave installed today
» Sheave installed today..
» Installed JBS Sheave today video
» new sheeve is installed
