| Installed JBS Sheave - Need Help | |
+1709-rhino700 ChrisH WV Hot Rod Rhino m1n1ster varmint10 RHINOMOON banchee6 Junglerider honda450sfm madmax 1 Hump scottwv ASPENDELLROVER CUSTOMIZEDRHINO13 T.Rhino rhino727 defstar 21 posters |
| Subject: Re: Installed JBS Sheave - Need Help Sun Jul 21, 2013 3:36 pm | |
| If it's hitting the rev limit, I wonder if the weights are what they are supposed to be. Maybe got in the wrong box from the factory or something. Are you running a cdi box? | |
defstar
Posts : 36 Join date : 2013-07-06 Location : Texas
| Subject: Re: Installed JBS Sheave - Need Help Sun Jul 21, 2013 5:05 pm | |
| No CDI here...bone stock...bad weights could be a possibility I guess...would bad weights affect the low to mid range as well?...I know my low to mid range feels about the same as stock (as I've mentioned before)...maybe just a tad lower but again no "wow" feeling... | |
Dan700
Posts : 23 Join date : 2013-03-31
| Subject: Re: Installed JBS Sheave - Need Help Sun Jul 21, 2013 5:42 pm | |
| well I am def in the same boat you are...I just haven't had time to mess with anything I just got a new job and haven't had time. but haven't had the wow factor either. Mine is bone stock to no mods expect for big horns stock tires | |
| Subject: Re: Installed JBS Sheave - Need Help Sun Jul 21, 2013 5:58 pm | |
| - defstar wrote:
- Alright guys...I just got back from further testing...I said before that my brothers bike was a 2012...it's actually a 2013 (sry about that) with less than 20 miles...we put the JBS sheave in it (with the 18g weights) and his factory primary sheave in mine...both of us are still using the factory secondary spring...
His bike did the exact same thing as mine did on the top end...from 40 to 49 it felt like the rev limiter was trying to kick in...also we drag raced again about a dozen times (switching bikes back and forth) and we either tied or he would edge me out by a nose from 0 to 40...
Just to remind everyone that before when the JBS was in my bike the top end rev limiter issue was there and when drag racing he was beating me by half a link...
I have not checked my wet clutch yet due to these results being so close together IMO with the JBS sheave in each of the bikes...
James...does this mean it's a sheave issue or do I still need to check my wet clutch?...is there a chance I was sent a 660 or 450 sheave by mistake or would that even make a difference?...
Please let me know what I need to do next...
Both our bikes are 700's and both are running stock tires...mine is a 2009 and his a 2013...my bike is also about 100 lbs heavier as I have a steel skid plate and some other protection parts...not sure if 100 lbs matters... very few have a rev limiter that hits a little earlier than others...you will have to run 20 gr until you get a cdi or go bigger on tires | |
| Subject: Re: Installed JBS Sheave - Need Help Sun Jul 21, 2013 11:42 pm | |
| I would be getting a cdi. If you swap weights, you will just be swapping them back after you get a cdi. | |
defstar
| Subject: Re: Installed JBS Sheave - Need Help Mon Jul 22, 2013 9:04 am | |
| Alright...so if I go CDI which one to get and how do you install them?...
Also...will this CDI correct everything and give me the "wow" factor in the low to mid range or just smooth the top end?...
I want all this awesome low to mid range from the sheave that everyone keeps talking about...
And in addition...if I do put the CDI on and then later my bigger tires...what then?...will anything need to be done with the CDI?... | |
| Subject: Re: Installed JBS Sheave - Need Help Tue Jul 23, 2013 4:58 am | |
| The cdi is an easy plug in install. It will take away that cutting out from hitting the rev limiter. So, it will pull good at 40+. The dynatek is what most people are running.
I can't answer you on the sheave only gains on a 700 as I done all of my mods at the same time. I can tell you that you run higher rpms durring acceleration from the lighter weights, rpms build a whole lot quicker right after the clutch engages, the clutch engages at a slower speed for more crawling ability and bottom end, and you gain top speed. I done the sheave and weights only on the 450 I had. It gained a few mph up hills, maintained more speed up hills, turned the tires over much better in mud and on hills where I needed to spin them, and increased top speed. I don't know if it would have outran a stock 450 from 0-35. Maybe not??? But I did pull out on the blacktop and pass a stock 450 pretty easy, but we were close to the stock top speed of one and above as we went by. It may be possible that a stock 700 can keep up til 40 due to the crappy flat cam that comes in them stock. They just don't seem to like to pull in the upper rpms, more of a torque engine in stock form.
You do need that cdi since you are hitting the rev limit. | |
defstar
| Subject: Re: Installed JBS Sheave - Need Help Tue Jul 23, 2013 9:46 am | |
| Thanks Hump...I may pass on the CDI and go ahead and order my wheels so I can put the 28's on...then adjust from there (as James suggested)...the cutting out at 40+ doesn't bother me...just the fact that I'm not "feeling" gains on the bottom end...though I may not be able to until I have a bigger tire on...
I will keep everyone posted on my results...it may be two or three weeks before I can get my wheels and test everything again...Dan700 feel free to post any of your findings if you try something different and anyone else with additional input please keep it coming in the meantime... | |
Dan700
| Subject: Re: Installed JBS Sheave - Need Help Tue Jul 23, 2013 10:10 am | |
| I will pry pass on the cdi also . Maybe later on I do something when I get some extra cash but right now the rhino runs and does what I want it to do. Kenny I hope everything works out for you keep me updated. sounds like we are in the same situation. | |
defstar
| Subject: Re: Installed JBS Sheave - Need Help Tue Aug 06, 2013 1:22 pm | |
| Ordered my wheels today...should have them by Friday and mounted up with my 28" outlaws...if all goes well I'll run some more testing Saturday and report back...I'm hoping that with the bigger tires on I'll be able to feel the JBS sheave helping more on the low end...I'm going to first run the stock sheave then switch over...maybe too with the taller tire it will kind of remedy the need for a CDI... | |
defstar
| Subject: Re: Installed JBS Sheave - Need Help Mon Aug 12, 2013 10:09 am | |
| Subject: Re: Installed JBS Sheave - Need Help Mon Aug 12, 2013 10:11 am | |
| Subject: Re: Installed JBS Sheave - Need Help Mon Aug 12, 2013 10:36 am | |
| forum GROUP HUG lol
glad you got it worked out | |
defstar
| Subject: Re: Installed JBS Sheave - Need Help Mon Aug 12, 2013 10:53 am | |
| Subject: Re: Installed JBS Sheave - Need Help Mon Aug 12, 2013 1:25 pm | |
| glad it worked, always nice to feel like your hard earned money was well spent! | |
| Subject: Re: Installed JBS Sheave - Need Help Mon Aug 12, 2013 1:28 pm | |
| Glad you got it worked out. | |
| Subject: Re: Installed JBS Sheave - Need Help Tue Aug 13, 2013 3:43 am | |
| I never thought about it because I don't know the spring/weight combos for each tire size. I swapped out weights on a grizzly 700 I used to own, and it just overreved the powerband. It was screaming, but not near as fast as stock. It had stock sized tires on it. I guess that's what was happening to you. Glad you like it with the new shoes. | |
| Subject: Re: Installed JBS Sheave - Need Help Tue Aug 13, 2013 8:34 am | |
| Subject: Re: Installed JBS Sheave - Need Help Tue Aug 13, 2013 9:57 am | |
| that's great glad you got it worked out! | |
| Subject: Re: Installed JBS Sheave - Need Help | |
