In total there are 18 users online :: 0 Registered, 0 Hidden and 18 Guests :: 1 Bot
Doin  some work on the rhino Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Doin  some work on the rhino Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Doin  some work on the rhino Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Doin  some work on the rhino Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Doin  some work on the rhino Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Doin  some work on the rhino Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Doin  some work on the rhino Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Doin  some work on the rhino Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Doin  some work on the rhino Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Doin  some work on the rhino Vote_lcapDoin  some work on the rhino Voting_barDoin  some work on the rhino Vote_rcap
chalkminer
JBFIREMAN
txgrown1404
UnderDawg
RiverRat
19 posters
Go to page : 1, 2, 3, 4, 5, 6  Next
Doin  some work on the rhino Empty
PostSubject: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 12:15 pm
doing some service on the rhino today... pics  and questions coming!!
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 12:17 pm
https://i.servimg.com/u/f33/18/33/06/20/20130710.jpg.     what's that bolt in between  the allen head bolts.... its loose
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 12:21 pm
cam chain tensioner..tighten it up..there is a bracket missing that holds the fuel line
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 12:25 pm
3rd owner and somebody has been in the side and changed apparently the stator.....
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 12:31 pm
head has been off and the clamp on the cvt exhaust boot is missing
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 12:41 pm
[url=Doin  some work on the rhino 20130711]
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 12:42 pm
[url=Doin  some work on the rhino 20130712][url=https://servimg.com/view/18330/28[/url]
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 12:50 pm
can someone  take pics of their motor so I can see where everything should go...? I think my harness is in the wrong spot,  it's pulling hard on my e-brake  micro switch wire
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 12:51 pm
you have a few things that need fixed...bolts missing out of cvt cover and the incerts are missing.,plug wire boot,throttle cable in wrong place,coil wires are in wrong place too and another cvt clamp is missing...
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 12:56 pm
I'm seeing all that now... Sad   all minor shit though
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 12:57 pm
yep ...all minor..just needs fixed
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 1:01 pm
thanks James what spark plug do u recommend
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 1:05 pm
i run the factory plug
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 1:40 pm
[url=Doin  some work on the rhino 20130713][url=https://servimg.com/imag[/url]e
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 2:22 pm
James , is the CVT fan really needed ? Mine is gone
http://www.trailbrightled.com
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 2:45 pm
 yours is made on the fixed...
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 2:47 pm
 dont know what caused that ..but i have them...belt is ridn to low in the secondary too...
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 2:49 pm
is it ok mine is missing 2 fins?   also diving into the wet clutch fir slugging how do I get the cover off with out dicking  it up
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 2:50 pm
why  would the belt be riding low?,  it's a new belt oem
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 6:25 pm
i cant believe how some people take care of their stuff, no attention to detail..not you Vern
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 6:40 pm
I know but I got a good deal so in a sense I'm p isssed but happy to have the rhino...    also just finished slugging the wet clutch forgot to  take pics...oops.   this is fun I see why James does it!
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 7:15 pm
glad you r enjoying it, there is always something to do, and a deal to be found!
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 7:16 pm
so will it hurt it to run this fan?
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 9:30 pm
[url=Doin  some work on the rhino 20130714][img]  easy way to hold the ckutches
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino Icon_minitimeThu Jul 11, 2013 9:38 pm
got the slugging done and put back together!   it accelerated  a lot better.  spun the tires faster Dancing Banana and  my throttle response is better...   all in all well worth it..  jbs  sheave and I will be in paradise!   thanks
Page 1 of 6Go to page : 1, 2, 3, 4, 5, 6  Next
» Show your Rhino at work
» Putting the Rhino to work in the snow
»  work
» I now have a Hot Rod Rhino
» somemore side work
