Doin  some work on the rhino - Page 5 Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Doin  some work on the rhino - Page 5 Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Doin  some work on the rhino - Page 5 Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Doin  some work on the rhino - Page 5 Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Doin  some work on the rhino - Page 5 Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Doin  some work on the rhino - Page 5 Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Doin  some work on the rhino - Page 5 Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Doin  some work on the rhino - Page 5 Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Doin  some work on the rhino - Page 5 Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Doin  some work on the rhino - Page 5 Vote_lcapDoin  some work on the rhino - Page 5 Voting_barDoin  some work on the rhino - Page 5 Vote_rcap
chalkminer
JBFIREMAN
txgrown1404
UnderDawg
RiverRat
19 posters
Go to page : Previous  1, 2, 3, 4, 5, 6  Next
Doin  some work on the rhino - Page 5 Empty
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeWed Jul 31, 2013 9:38 pm
no broken bolt,  got pics but they won't load....    it must have been a glare  on the original pic,    but it's a beast  on the low end, it's got the rpm  just seems like it won't shift to top gear....
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeWed Jul 31, 2013 9:43 pm
Did u check the fuel filter to see if its clooged,just trying to help.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeWed Jul 31, 2013 9:45 pm
I just cant figure out why with a jbs sheave it wont run any faster than a stock 700.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeWed Jul 31, 2013 9:52 pm
have not checked the fuel filter.... hmmmm
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeWed Jul 31, 2013 10:05 pm
Fuel filter,spark plug,air filter.and valve adjustment,turn the flywheel to tdc,then check valve clearance,maybe the valves have sunk into the head and you don't have any clearance.therefore the valves are not closing all the way thus no compression.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeWed Jul 31, 2013 10:11 pm
I will do more checking,  thanks u appreciate the input!
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeThu Aug 01, 2013 9:54 am
[url=Doin  some work on the rhino - Page 5 20130718]
Mud Rat
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeThu Aug 01, 2013 11:39 am
when i serviced my secondary i put too much grease in and it had a low top speed...so i removed some and jacked the back end up off the ground and was able too see 50 mph...went for a test ride and had 48 mph
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeThu Aug 01, 2013 12:13 pm
ok thanks I will check that too.  I'm up for all suggestions,  just wanna get my rig running properly
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeThu Aug 01, 2013 2:22 pm
i need better pics of the sheaves
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeThu Aug 01, 2013 2:37 pm
different angles..?   what parts specifically and I will go my best,  my jbs  is great now sugarbear  helped  me out on that one
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeSun Aug 04, 2013 2:33 pm
so I raced a stock  rhino with a extended cage yesterday  and he literally destroyed me.. I jumped him off the line to about 15 mph  then he blew by me like nothing.......   think I have low  compression?.. or a wore  out  cam?  gunna check compression today ... what should it be at?
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeSun Aug 04, 2013 3:39 pm
cam off a tooth maybe
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeSun Aug 04, 2013 3:52 pm
ok, can I check that  through the inspection cover?
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeWed Aug 14, 2013 1:19 am
got my teryx shocks on tonight, thanks again mike!!
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeWed Aug 14, 2013 1:20 am
[url=Doin  some work on the rhino - Page 5 20130810][url=https://servimg.com/view/18330620/51[/url]
dont judge my dirty rhino  :-)
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeWed Aug 14, 2013 1:22 am
almost 15" in the front:  on the lowest setting. ..... and 14 3/4  in the rear.... plus its stiff till I get my cage put back in...
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeWed Aug 14, 2013 2:32 am
holy shit Vern, thats a lot of angle on those CV's. is that how all rhino's look with those shocks? looks crazy bro? how is it on the trail?
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeWed Aug 14, 2013 2:45 am
it only lifted me 1 1/2  inches  in the rear,  it looks worse than it is....  got the shocks today and put them on today lol couldnt  wait...  but she stiff
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeWed Aug 14, 2013 2:54 am
i only have 13" GC with 25's and +6 LT. hope it performs good
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeWed Aug 14, 2013 10:04 am
my tires are 25's too,  it should be good
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeSat Aug 17, 2013 3:56 am
UPDATE:   tore  down the rhino tonight,  and sure enough I was off a tooth on my cam  and my  valves were way out of adjustment.  got it all tdc  and took it for a ride.  and hit 46  but still not hitting the rev.  limitter..  but it's allot better..   still need to adjust my toe in and my tps  is at 95  with my cable fully adjusted...
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeSat Aug 17, 2013 9:36 am
Atleast your headed in the right direction,and solving problems.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeSat Aug 17, 2013 9:59 am
cheers
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 5 Icon_minitimeMon Aug 19, 2013 11:38 pm
Ok adjusted my tps and now I'm at 19 &98,  and hit 48 mph  still no  rev-limiter....  dunno what else I can go to  try and hit the limiter,    I figured  out the guy has replaced the stator probly why my cam was off a tooth..  from their I'm lost in what else to do... any ideas guys?
Page 5 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» Show your Rhino at work
» Putting the Rhino to work in the snow
»  work
» I now have a Hot Rod Rhino
» somemore side work
