In total there are 7 users online :: 0 Registered, 0 Hidden and 7 Guests :: 2 Bots
Doin  some work on the rhino - Page 6 Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Doin  some work on the rhino - Page 6 Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Doin  some work on the rhino - Page 6 Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Doin  some work on the rhino - Page 6 Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Doin  some work on the rhino - Page 6 Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Doin  some work on the rhino - Page 6 Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Doin  some work on the rhino - Page 6 Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Doin  some work on the rhino - Page 6 Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Doin  some work on the rhino - Page 6 Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Doin  some work on the rhino - Page 6 Vote_lcapDoin  some work on the rhino - Page 6 Voting_barDoin  some work on the rhino - Page 6 Vote_rcap
chalkminer
JBFIREMAN
txgrown1404
UnderDawg
RiverRat
19 posters
Go to page : Previous  1, 2, 3, 4, 5, 6
Doin  some work on the rhino - Page 6 Empty
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeMon Aug 19, 2013 11:39 pm
could it be a wet clutch  or would it slip and let me hit my limiter...?
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeTue Aug 20, 2013 6:47 am
I don't see any connection between the replacing the stator and messing up your cam timing, on my 700 I can hit 49-50 fairly quickly and if I wait it will on flat gravel go 52-53 and never hit what I call a rev limiter. When my Rhino reaches about 52 or so it just won't go faster, but no miss or cutting out is felt. On pavement it will go 55-56,slight decline 59 and still with the 8000 RPM red line it won't hit a rev limiter I chicken out first, it sounds like its reving way to fast.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeTue Aug 20, 2013 10:04 am
mine takes what seems to be longer than it should...  maybe I'm wrong,....well if they  pulled the stator and didn't line up the decks just way with the tdc  Mark in the case,  then none of the marks on the cam will even matter cause the initial alignment of the crank at tdc  will be off.. right? I'm still learning bout this so I could be wrong....
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeTue Aug 20, 2013 10:37 am
what kind of rpm's  should I be seeing,  if I need to go but a trach I  will...
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeTue Aug 20, 2013 11:09 am
I am not sure I don't have a tach,but my MSD is set @8000RPM.and have never had the feeling of a rev limiter,like when it was stock,it just would not go faster.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeTue Aug 20, 2013 11:23 am
thanks for your input, I just wanna make sure it runs correctly,  do I don't jack something up
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeTue Aug 20, 2013 11:25 am
Cool.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeTue Aug 20, 2013 2:13 pm
it will be when I know it's good lol...  maybe a cdi would help?
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeTue Aug 20, 2013 3:57 pm
Your sheave and the CDI will compliment each other.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeTue Aug 20, 2013 4:32 pm
if I could find someone to loan me one and see if it helps that would be awesome...lol
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeTue Oct 01, 2013 1:10 am
ok  so I didn't think my timing was on so I tore it down again and found out was of a tooth,  from when I thought I fixed it..  so now I took it for a ride it gets to 30 mph  then it seems like it loses power then eventually gets to 43mph...  coukd it be weights....  wet clutch.... secondary clutch..?   goin on a elk hunt Friday was hopin that would fix it....
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeTue Oct 01, 2013 2:16 am
Vern before when you timed it you where at 48 an now it takes a while to hit 43 maybe timing still off what about valve clearance    Question
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeTue Oct 01, 2013 10:04 am
I setup.the valves  to stock spec,  eveything at TDC.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeTue Oct 01, 2013 11:31 am
the only thing I haven't checked is the fuel filter... would this cause my problem?  also is it in the tank?
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeTue Oct 01, 2013 4:33 pm
I believe its at the end of the fuel pickup, its probably OK your fuel tank would have be very dirty to cause a problem.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeThu Oct 03, 2013 4:47 pm
Could I have a flopped weight...?   our maybe have a 660  clutch on accident?   thanks for helpin me guys
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeThu Oct 03, 2013 9:19 pm
I don't think you can flip a weight if its together but you can flip one when installing your sheave. Watch
James videos about the sheave greasing, weight install see if something rings a bell for you. I hope you can get out and fill your tag good luck.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeFri Oct 04, 2013 1:49 am
I will take some pics,  the area I'm goin to is awesome..  thanks for all your input bro.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 6 Icon_minitimeFri Oct 04, 2013 10:53 am
Cool
Page 6 of 6Go to page : Previous  1, 2, 3, 4, 5, 6
» Show your Rhino at work
» Putting the Rhino to work in the snow
»  work
» I now have a Hot Rod Rhino
» somemore side work
