In total there are 14 users online :: 0 Registered, 0 Hidden and 14 Guests :: 2 Bots
Doin  some work on the rhino - Page 4 Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Doin  some work on the rhino - Page 4 Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Doin  some work on the rhino - Page 4 Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Doin  some work on the rhino - Page 4 Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Doin  some work on the rhino - Page 4 Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Doin  some work on the rhino - Page 4 Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Doin  some work on the rhino - Page 4 Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Doin  some work on the rhino - Page 4 Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Doin  some work on the rhino - Page 4 Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Doin  some work on the rhino - Page 4 Vote_lcapDoin  some work on the rhino - Page 4 Voting_barDoin  some work on the rhino - Page 4 Vote_rcap
chalkminer
JBFIREMAN
txgrown1404
UnderDawg
RiverRat
19 posters
Go to page : Previous  1, 2, 3, 4, 5, 6  Next
Doin  some work on the rhino - Page 4 Empty
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeSun Jul 28, 2013 8:07 pm
Also what oil did u put in when u changed it,was it wet clutch approved?
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeSun Jul 28, 2013 8:24 pm
yamaha  brand wet clutch semi synthetic
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeSun Jul 28, 2013 8:30 pm
No problem there.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 2:53 am
what would make my belt ride low,  with a news belt
Yotehunter66
Moderator
Yotehunter66
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 7:18 am
Would not be a bad idea to pull the secondary while you have the cover off and clean and regrease the pins. You could do the washer mod while you're in there.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 8:18 am
That would be a good idea,then dont think about it for a couple of years,unless really dusty.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 9:40 am
I.serviced.the secondary just after.I bought, what washers..? anti friction from jbs? cause they are in ...
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 9:47 am
belt shouldnt be ridn low...we need pics
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 9:54 am
someone said it should be should ridin  1/8  inch above the top of my sheave...  I will  tear it down tonight and take some pics,  the pic in the firstof this thread shows how the belt is still riding if that helpd  at all
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 10:03 am
i see the problem.....there are bolts broke off in the secondary stopping the sheaves from closing all the way
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 10:09 am
I will look close when I tear it down, you may be right. I know for sure one isn't because I used it to seperate it when  I put thr anti friction washers on, not sure about the other.  could that be why im not getting top end too?
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 10:16 am
yep...weights flipping over
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 10:23 am
thanks James, what size is the  socket I  need for big nut on the secondary in know the front nut is 22mm,  but I didn't have a metric  socket ans had to use standard.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 11:36 am
1 13/16
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 12:57 pm
thanks
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 4:56 pm
how much is a new secondary sheave if I end up needing one?
Yotehunter66
Moderator
Yotehunter66
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 5:18 pm
Sure looks like a broken bolt in the secondary. As long as the belt surface looks good I would try and drill it and use an extractor to remove it.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeMon Jul 29, 2013 5:55 pm
if there is one broke off its in deeper than flush, because I can fully put a bolt  in one hole to seperate the sheave to pull the belt the other hole starts but doesnt go in but half a turn..  maybe there is something in there.. should have looked at it better..
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeTue Jul 30, 2013 11:03 pm
UPDATE!!!!!!    With the help of  sugarbear  we managed to get the rhino running better, I had the weights in wrong.  I can now  hit 41  downhill.  maybe I need a different secondary spring..?       any thoughts?
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeWed Jul 31, 2013 9:55 am
I was able to hit 43. with just me in it down hill
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeWed Jul 31, 2013 11:30 am
should be able to do 48-50 on a down hill with any tires
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeWed Jul 31, 2013 1:42 pm
so when I pulled my secondary with the belt still on..  when I  removed the belt it  closed all the way.  could my secondary spring be weak and not able to close all the way and make it put the belt where it needs to be fit proper gearing...?
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeWed Jul 31, 2013 8:50 pm
could it be a  cam  position  problem?  James you said in the first of my thread that the head had been off,  could they be off a tooth when they re-installed  it?   just a thought.   also how could you tell the head had been off?
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeWed Jul 31, 2013 9:03 pm
I guess the cam could be retarded 1 tooth,then it would not have much top end,and it would be very sluggish from the getgo.
PostSubject: Re: Doin some work on the rhino   Doin  some work on the rhino - Page 4 Icon_minitimeWed Jul 31, 2013 9:16 pm
Did you get the broke bolt out of the secondary?
Page 4 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» Show your Rhino at work
» Putting the Rhino to work in the snow
»  work
» I now have a Hot Rod Rhino
» somemore side work
