| Subject: Re: 660 Rear brake growling noise Fri Apr 26, 2013 5:08 pm | |
| - onebuilder wrote:
- Do like I did, print off both pages for the rear wheels for the '06 and '08 and compare.
Basically
Axle nuts 2 Rear Uprights- left and right Hubs- 2 Rotors- 2 Calipers left and right Rear Brake hose- left to right wheel Brake pipe- or add on to the 660 Cap for the brake line at the 660 caliper or convert to the 700 ebrake caliper. The 660 ebrake cable hooks up the same. Brake fluid Ive been wanting to do the same thing to mine as soon as money permits!!! is the stopping power much better? | |
| Subject: Re: 660 Rear brake growling noise Fri Apr 26, 2013 5:14 pm | |
| Yes it is better. Especially at high speeds.
The rear pads are the same as the front pads on the '08, just reversed side for side. More pad surface in contact with the rotor and less heat on the dual rotors compared to the single rear on the 660. | |
| Subject: Re: 660 Rear brake growling noise Fri Apr 26, 2013 5:45 pm | |
| Thanks,can't wait to get all the stuff together!! | |
| Subject: Re: 660 Rear brake growling noise | |
