| rebuild WARN winch or upgrade??? | |
+4T.Rhino 123.bert0621 08Rhino450SE kris55 8 posters |
kris55
Posts : 46 Join date : 2013-03-15 Age : 46 Location : Iron Range area, MN
| Subject: rebuild WARN winch or upgrade??? Thu Sep 05, 2013 3:48 pm | |
| So I have an RT or XT 30 winch on my rhino that has seemed to not want to reel in the cable when it should, I hear the motor going but it will not reel in, and is actually easy to get more cable to pull out even when it shouldn't be.
So I see WARN has a warranty, but is it worth rebuilding for this issue, or would it just be better to get a viper max 5,000lb winch, or even supermaxx 4,000lb winch? Thanks for input on this issue. | |
| Subject: Re: rebuild WARN winch or upgrade??? Thu Sep 05, 2013 4:12 pm | |
| is it steel or synthetic cable? steel cable is a real bitch if you don't wind/unwind diligently. it will kink up and crack. flimmy sells synthetic cable cheap enough. if the motor spins freely that's what i would do | |
| Subject: Re: rebuild WARN winch or upgrade??? Thu Sep 05, 2013 6:56 pm | |
| I don't know what it would cost, but after you have rebuilt its still an old winch, I think that a new one with the rope would be a better move, just my opinion. Good luck what ever you decide, I think Flimmy also sells winches. | |
| Subject: Re: rebuild WARN winch or upgrade??? Thu Sep 05, 2013 9:35 pm | |
| Synthetic is the way to go I can turn mine on free spool and throw it at what ever I'm trying to hook to. My winch messed up like that and I disassembled it and cleaned all the mud out and helped it out alot. | |
| Subject: Re: rebuild WARN winch or upgrade??? Thu Sep 05, 2013 9:43 pm | |
| Thanks guys , I do sell Viper winches and if your interested in one let me know.
A Viper elite 5000 I could do $430 shipped to you. That's about a $70 savings off retail
That's just the winch w/o the mounting plate since you already have a winch this would be just a direct swap. It will come with everything else. | |
JBFIREMAN
| Subject: Re: rebuild WARN winch or upgrade??? Fri Sep 06, 2013 8:09 am | |
| If you go new I mite take your old one thanks John | |
kris55
| Subject: Re: rebuild WARN winch or upgrade??? Fri Sep 06, 2013 10:50 am | |
| It's a steel cable now. It's not bound up in the spool though as I had a bunch of it pulled out already, it's like the gears are stripped inside. I sent an email to warn about it, I hate to spend the money on a new one right now if I don't have to, but if its not warranted and is a bitch to rebuild it might just be worth it to in the end. Gonna wait to hopefully hear back from warn before deciding for sure what to do. | |
| Subject: Re: rebuild WARN winch or upgrade??? Fri Sep 06, 2013 1:37 pm | |
| - kris55 wrote:
- It's a steel cable now. It's not bound up in the spool though as I had a bunch of it pulled out already, it's like the gears are stripped inside. I sent an email to warn about it, I hate to spend the money on a new one right now if I don't have to, but if its not warranted and is a bitch to rebuild it might just be worth it to in the end. Gonna wait to hopefully hear back from warn before deciding for sure what to do.
Have you properly turned the spool-out control knob back to the winching position? It could be that the control is jammed or crudded up such that it did not get back into the 'locked' position? | |
kris55
| Subject: Re: rebuild WARN winch or upgrade??? Fri Sep 06, 2013 3:28 pm | |
| - SteveS wrote:
Have you properly turned the spool-out control knob back to the winching position? It could be that the control is jammed or crudded up such that it did not get back into the 'locked' position? It seems to be, I've tried going back n forth to the "winch" "free spool" position several times while looking at it, even with no load on it at all it will not winch the cable back in. I'll see about taking it apart and maybe it does need to be cleaned as it's not fully locked into the winch position becasue of dirt/debris etc. | |
JBFIREMAN
| Subject: Re: rebuild WARN winch or upgrade??? Fri Sep 06, 2013 4:42 pm | |
| Take it apart and hope you can fix it those thing aint cheep I had the same thing with mine and got it working,mine was a cheepo but is still working knock on wood good luck | |
kris55
| Subject: Re: rebuild WARN winch or upgrade??? Tue Sep 10, 2013 9:34 am | |
| Got an email back from Warn, they said to take it apart and see if it is stripped in the clutch area, if so I'll need to take it to an authorized warn dealer for parts, and to see if it qualifies for warranty. On the plus I just found out a friend is actually a dealer for them through his small engine repair shop he has. only downfall is I am not the original owner, but maybe we can figure a way around that. Hoping I can get it apart this week to see, and really hoping I can get it repaired under warranty if it needs it. Fingers crossed! | |
JBFIREMAN
| Subject: Re: rebuild WARN winch or upgrade??? Tue Sep 10, 2013 3:37 pm | |
| thats great hope so Goodluck | |
| Subject: Re: rebuild WARN winch or upgrade??? Tue Sep 10, 2013 6:22 pm | |
| That's lucky,hope he can help. | |
soarkrebel
| Subject: Re: rebuild WARN winch or upgrade??? Tue Sep 10, 2013 11:01 pm | |
| Rebuild. They are simple and if you do it right....it's a new winch that looks old.. | |
kris55
| Subject: Re: rebuild WARN winch or upgrade??? Thu Sep 26, 2013 8:50 pm | |
| Ok. Finally got a chance to talk to my friend and look at the winch again. He said to check the plastic cover piece that you turn to free spool and winch modes, he said to try and push that cover in and see if it works then, as the plastic piece will warp and not have enough bite to push the pins to grab in winch mode all the way. Sure enough that was the problem. So now I just have to order the plastic cover piece and swap it out. Hope this helps anyone else that may have issues. Glad it's an inexpensive easy fix! | |
| Subject: Re: rebuild WARN winch or upgrade??? Thu Sep 26, 2013 9:44 pm | |
| - kris55 wrote:
- Ok. Finally got a chance to talk to my friend and look at the winch again. He said to check the plastic cover piece that you turn to free spool and winch modes, he said to try and push that cover in and see if it works then, as the plastic piece will warp and not have enough bite to push the pins to grab in winch mode all the way. Sure enough that was the problem. So now I just have to order the plastic cover piece and swap it out. Hope this helps anyone else that may have issues. Glad it's an inexpensive easy fix!
Good for you! Have at it now. For what it is worth, you can often rehabilitate warped plastic parts by using a heat gun to warm up the part and forcing it back into its proper shape. Hold it until it cools down where it needs to be. Use gloves, as it needs to be pretty hot.
JBFIREMAN
| Subject: Re: rebuild WARN winch or upgrade??? Thu Sep 26, 2013 9:46 pm | |
| Thats great glad you got it and a big money saver | |
| Subject: Re: rebuild WARN winch or upgrade??? Thu Sep 26, 2013 11:24 pm | |
| - SteveS wrote:
- Have you properly turned the spool-out control knob back to the winching position? It could be that the control is jammed or crudded up such that it did not get back into the 'locked' position?
Uncle Steve to the rescue once again | |
| Subject: Re: rebuild WARN winch or upgrade??? Thu Sep 26, 2013 11:40 pm | |
| - 08Rhino450SE wrote:
Uncle Steve to the rescue once again Ha, Ha. Thanks, bro's kid. LOL. There is nothing that a precise gentle tap with a Big Hammer cannot cure... Usually... | |
| Subject: Re: rebuild WARN winch or upgrade??? Fri Sep 27, 2013 6:37 am | |
| Subject: Re: rebuild WARN winch or upgrade??? | |
