| 660 rear differential and chassis rebuild | |
+7flimmy Jet REDRHINO64 WV Hot Rod Rhino rhino727 123.bert0621 Baxter Built Fabrications 11 posters |
| Subject: Re: 660 rear differential and chassis rebuild Tue Oct 29, 2013 3:09 am | |
| This is the back horizontal tube that the rear diff mounts came off of.There's no saving that. Lol It's a crap pic but that a big hole broke out of it. This is a pic of the tabs before I lined everything up.The were ground to fit in the factory horrizontal tube before I cut it out. All clean up and ready for new. | |
| Subject: Re: 660 rear differential and chassis rebuild Tue Oct 29, 2013 3:31 am | |
| this is the plate I cut and dimpled to go across the top.It's made to increase the surface area of weld so that it's spreads the load over the entire mount. I tacked it all together then made sure I could still get the diff out and welded the plate across the top. all painted and ready for assembly and yes the exhaust comes in and out of it still. Lol That was another thing I checked before I pored the coals to it and made it all permanent.That may all be overkill but he won't have to check them all the time with that setup. | |
| Subject: Re: 660 rear differential and chassis rebuild Tue Oct 29, 2013 5:29 am | |
| Oh,I think I'm going to work on a A arm tower brace for the rear before I finish it up.Those I'll make some up and shelf them.It's dumb I haven't done it yet.I may use his for mach up for a "weld in" boxed set up for in between the towers.Mine are bent to hell on my 08.Better use a straight one then beat mine till they fit sorta thing.lol | |
| Subject: Re: 660 rear differential and chassis rebuild Tue Oct 29, 2013 7:53 am | |
| Subject: Re: 660 rear differential and chassis rebuild Tue Oct 29, 2013 8:03 am | |
| Subject: Re: 660 rear differential and chassis rebuild Tue Oct 29, 2013 10:43 am | |
| Subject: Re: 660 rear differential and chassis rebuild Tue Oct 29, 2013 10:56 am | |
| great lookin' work, Jason. love the welds it's nice to make things the way you want instead of paying somebody else for beta testing their work. | |
| Subject: Re: 660 rear differential and chassis rebuild Tue Oct 29, 2013 11:23 am | |
Tacoclaw
Posts : 29 Join date : 2013-09-28
| Subject: Re: 660 rear differential and chassis rebuild Tue Oct 29, 2013 2:28 pm | |
| Dang, I wish mine looked that good. | |
| Subject: Re: 660 rear differential and chassis rebuild Thu Oct 31, 2013 12:02 pm | |
| Jason, i'm curious as to how you make and why you use dimples. They look really cool, but i don't know their function... Do you use a press and a die? Does it add flex or strengthen the metal? Forgive my ignorance, i have no experience in these matters | |
| Subject: Re: 660 rear differential and chassis rebuild Thu Oct 31, 2013 2:13 pm | |
| Subject: Re: 660 rear differential and chassis rebuild Thu Oct 31, 2013 2:50 pm | |
| That's right and they look really cool. | |
| Subject: Re: 660 rear differential and chassis rebuild Thu Oct 31, 2013 9:54 pm | |
| Subject: Re: 660 rear differential and chassis rebuild Sat Nov 02, 2013 5:36 am | |
| I've got dies that do it in a press.if the holes are staggered right when you use them they make thin steel quite a bit stronger and yes they look cool. Lol | |
Wht07rhino
Posts : 104 Join date : 2013-10-15 Age : 38 Location : Celina,OH
| Subject: Re: 660 rear differential and chassis rebuild Thu Nov 07, 2013 5:04 pm | |
| You have some top notch fan work going on here Baxter..... definitely don't think this customer will have an issue now.... | |
| Subject: Re: 660 rear differential and chassis rebuild Sat Nov 09, 2013 11:09 am | |
| Subject: Re: 660 rear differential and chassis rebuild Mon Nov 11, 2013 3:49 am | |
| I guess I never posted a pic of the finished product. | |
| Subject: Re: 660 rear differential and chassis rebuild Tue Nov 12, 2013 11:36 am | |
| Sweet Jason, nice finishing touch. | |
| Subject: Re: 660 rear differential and chassis rebuild | |
