In total there are 117 users online :: 0 Registered, 0 Hidden and 117 Guests :: 2 Bots
Advice needed Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Advice needed Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Advice needed Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Advice needed Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Advice needed Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Advice needed Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Advice needed Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Advice needed Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Advice needed Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Advice needed Vote_lcapAdvice needed Voting_barAdvice needed Vote_rcap
 Advice needed
4 posters
TBOMB
Advice needed Empty
PostSubject: Advice needed   Advice needed Icon_minitimeMon Nov 04, 2013 6:46 pm
Noticed gear oil leaking from around rear seal area of front diferential. Anyone had any experience with this? Is it common for the seals to give out after a length of time or is it more likely that a bearing is on its way out causing the seal to leak? Any advice/help is greatly appreciated.
Advice needed Empty
PostSubject: Re: Advice needed   Advice needed Icon_minitimeMon Nov 04, 2013 10:30 pm
My 06 doing same thing. I just ordered the seals from James.
I play a lot in mud and water so it takes a toll on seals.
TBOMB
Advice needed Empty
PostSubject: Re: Advice needed   Advice needed Icon_minitimeTue Nov 05, 2013 9:50 am
Thanks for the reply! Looks like it will be a pain in the butt to pull differential out of chassis. I guess I will pull it and check everything out and order seals if that appears to be all I need.
CamoRhino660
CamoRhino660
Advice needed Empty
PostSubject: Re: Advice needed   Advice needed Icon_minitimeTue Nov 05, 2013 5:46 pm
Some times it's just the big nut behind the driveshaft none to work loose.... Red locktight it when you put it back together. That's what my 06 did.
TBOMB
Advice needed Empty
PostSubject: Re: Advice needed   Advice needed Icon_minitimeTue Nov 05, 2013 7:14 pm
Thank for the reply CamoRhino! I haven't had a chance to check anything out yet, but was just wondering if this was a common problem as the seals aged. I had it out at the hunting camp a couple of weeks ago and everything was okay. Did not notice any leakage on the ground or on the trailer after I got it home. Couple of days later though, and gear oil was on the garage floor and all around the rear seal. I will be sure to check the nut on the yoke collar. Thanks for the input.
Wingman
Advice needed Empty
PostSubject: Re: Advice needed   Advice needed Icon_minitimeTue Nov 05, 2013 7:44 pm
The nut on mine came loose also, it was an 06 and I got the seal from James. I am starting to see a pattern .... I think James has something to do with it!!
Advice needed Empty
Advice needed
» Axle help needed
» new to the forums and need advice
» 450 snorkel advice
» advice on the muzzy mounts
» Needing advice on wheel offset
HOTRODRHINOFORUMS.COM :: Technical :: drivetrain-
