| Yanmar diesel into '06 660 Rhino | |
+20Rhinofire13 Snorider JBFIREMAN weekendwarriorfsw32 Bender.chris5908 madmax 1 phuzzie09 CUSTOMIZEDRHINO13 SteveS Deuces wild Firefighter REDRHINO64 WV Hot Rod Rhino scottwv Baxter Built Fabrications chuddly slomo KJrhino flimmy Bodacious 24 posters |
phuzzie09
Posts : 4 Join date : 2013-04-04
| Subject: Re: Yanmar diesel into '06 660 Rhino Thu Apr 04, 2013 8:37 pm | |
| put the rhino plastics on the ranger..... | |
Bodacious
Posts : 36 Join date : 2013-03-17 Location : Weston, WV
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Apr 07, 2013 11:56 am | |
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Apr 07, 2013 12:08 pm | |
Bodacious
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Apr 28, 2013 9:54 am | |
| Hello all, Sorry its been a while since my last post. Weather is really nice and the spring surge to move dirt has hit...also have some other stuff going on. Anyhow I've made a little progress only to have to back up. When I cut the axles for length, I figured when the suspension compressed it would push the axle in. I should have went ahead and removed the spring and cycled the suspension, but, I was pretty confident I was right. Well, it turns out that the axle doesn't move in and out much at all as the suspension cycles. So, even though the axles would have worked at the length I cut them, the CV balls would have been running on the outside lip of the cup making them extremely week. I fixed the rear by deleting the sway bar and dropping the diff down. This also removed some of the angle from the CV's. On the front, the axles will have to be cut apart and a new sleeve built. I think I'm about to drive my machinist up the wall. lol I did get coolant lines ran. I will post pics of them later on. I'm glad they are very malleable as I had to re-bend several times to get them right. I finished mounting the turbo and wrapped my header. I posted some pics of a little trick I tried that seemed to work well. I have wrapped exhaust before only to have the wrap eventually loosen up and slide down off the pipes. So, I got some really small tig rods and tig'd them to the pipes. These little barbs gave the wrap something to adhere to. Once wrapped, I took a small hammer and either battered the ends of the barbs or bent them over. It was a little time consuming, but, I believe the time here will pay off on the trail. I also got the exhaust pipe fabbed up and will be wrapping it to at least past the plastic belt cover. Here are some pics. Enjoy..... | |
Bodacious
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Apr 28, 2013 10:13 am | |
| Question on the deletion of the sway bar. James gave me the idea and said it was part of a factory recall. If this were yours, would you re-mount the sway bar or would you just leave it off? We work this thing more than we sport it and I'm wondering if it will go around a side of a hill with a full load of fire wood like it used to? | |
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Apr 28, 2013 11:16 am | |
| it handles better with it off and handles even better if you put it on the front..i run one in the front and the rear unhooked | |
Bodacious
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Apr 28, 2013 11:46 am | |
| Is your front a custom install? or a kit?
The Polaris is mounted to the back of the frame stiffeners between the top and bottom frame rails. I could put the rhino sway bar back on like the Polaris, but, if I don't need it why go to the work? | |
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Apr 28, 2013 11:49 am | |
| took mine off rear like it much better without | |
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Apr 28, 2013 11:50 am | |
| Lookin good! I like the exhaust tip! Have you been able to run it yet? | |
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Apr 28, 2013 11:51 am | |
| if you have a rear and no front they handle like shit...mine is aftermarket but you cant get them anymore....i think the rear one might mount to the front some how.. | |
Bodacious
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Apr 28, 2013 3:54 pm | |
| Ok James. Thanks for the reply. I will probably just have to wait and see whats best for my application. Do you still have the safety belts? I still need 'em if you are interested.
Customized Rhino 13,
Haven't had it running yet. I am wait'n on some special order boost hoses. I need Jame's friend to take a trip to Illinois for me. LOL I am going to try and get everything bolted up tonight and put some water to it. Hopefully I'll have no leaks. Yea, couldn't possibly have a diesel without some sorta custom tip. lol
By the way, I sold the engine yesterday to a fella from Masontown. I still have the diffs I need to get rid of. The front is like a new one but the rear is the only stock piece that has survived the life of the Rhino.
I also spoke with my pump guy the other day. The engine that made 123HP was fitted with a deutz pump. I may have to get bigger tips on the injectors to get to the 60HP goal. I'd like to stay away from a big dollar pump if I can. | |
Bodacious
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Apr 28, 2013 10:13 pm | |
| That thing should be a beast when u get it done!!! | |
Bender.chris5908
Posts : 33 Join date : 2013-03-11 Location : Central pa
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Apr 28, 2013 10:18 pm | |
| - WV Hot Rod Rhino wrote:
- it handles better with it off and handles even better if you put it on the front..i run one in the front and the rear unhooked
can you post pics on how you mounted it up.. and did you use a rear sway bar in the front | |
| Subject: Re: Yanmar diesel into '06 660 Rhino Mon Apr 29, 2013 12:53 am | |
can you post pics on how you mounted it up.. and did you use a rear sway bar in the front i think the rear would work on the front...mine is aftermarket..will post pics | |
weekendwarriorfsw32
Posts : 22 Join date : 2013-03-18 Location : Bay area
| Subject: Re: Yanmar diesel into '06 660 Rhino Thu May 16, 2013 5:30 pm | |
Bodacious
| Subject: Re: Yanmar diesel into '06 660 Rhino Sat May 18, 2013 9:14 am | |
| I'm still waiting on boost hoses. I should probably just use radiator hose and get 'er going. lol | |
JBFIREMAN
| Subject: Re: Yanmar diesel into '06 660 Rhino Sat May 18, 2013 10:39 am | |
| This thing is going to be cool | |
Snorider
| Subject: Re: Yanmar diesel into '06 660 Rhino Mon Jun 03, 2013 2:10 am | |
| I agree looking forward to this thing running and seeing video and reports back. | |
Rhinofire13
Posts : 91 Join date : 2013-05-04 Age : 57 Location : Hudson Vally NY
| Subject: Re: Yanmar diesel into '06 660 Rhino Mon Jun 03, 2013 4:40 am | |
| You are doing some great work it looks good. | |
Bodacious
| Subject: Re: Yanmar diesel into '06 660 Rhino Sat Jun 08, 2013 11:08 pm | |
| Hello all. She's finally alive. I'm still waiting on the boost hoses. However, I used some old radiator hose and fab'd up a temporary setup. We turned the fuel screw out 4 full turns. It went from 2 lbs boost on stock fuel to 7 lbs with the 4 turns out. I'm anxious to get it beside a stock Rhino to see how she fares. I'm gonna go ahead and order larger injector tips and I think I'll stop at that point. EGT's have not gone above 600. I'm not sure how much these little engines will stand. I don't think I'm gonna be able to get to the original 60hp mark with this injection pump. Maybe later down the road I'll spring for a better pump, but for now, if she'll stay with a stock Rhino I'll be happy. Check out the vid https://www.youtube.com/watch?v=Z9qtZxGT82M&feature=youtu.be | |
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Jun 09, 2013 2:53 pm | |
| Pretty cool , I wonder what kind of fuel mileage you will get out of it. | |
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Jun 09, 2013 3:15 pm | |
| that thing is bad ass. i think there's a set of wheelie bars in your future | |
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Jun 09, 2013 5:02 pm | |
| very nice , lots of work done right an it shows , can't wait to see it on the trails, super nice welds your son will get work welding like that | |
| Subject: Re: Yanmar diesel into '06 660 Rhino Sun Jun 09, 2013 9:44 pm | |
| Nice! That things got some torqe! Rollin coal with a rhino, that's pretty badass! | |
| Subject: Re: Yanmar diesel into '06 660 Rhino | |
