| tips and tricks | |
+27Bayou Tiger 123.bert0621 JOHN DILLARD UnderDawg xjcrawler TrunkMonkey RADICAL RAM rhino727 madmax 1 rhino21 KJrhino SteveS Firefighter REDRHINO64 CUSTOMIZEDRHINO13 Randy3451 chuddly Kenny G scottwv onebuilder flimmy banchee6 Quadog Jet foyota86 T.Rhino WV Hot Rod Rhino 31 posters |
| Subject: tips and tricks Thu Apr 11, 2013 2:13 pm | |
| Subject: Re: tips and tricks Thu Apr 11, 2013 2:17 pm | |
| first tip is .....dont let teddy drive your rhino..lmao | |
| Subject: Re: tips and tricks Thu Apr 11, 2013 2:31 pm | |
| That was funny shit. But your still a ass. Lol | |
| Subject: Re: tips and tricks Thu Apr 11, 2013 2:38 pm | |
| All rightly then and thanks! I will put my first tip on this bad boy, yall don't hurt my feelings if yall already done it or know something better (but if you do fire away). These things have a lot of rattles, squeaks and chit. My bed was a big issue. I just wrapped some electrical tape around the rubber guides that the gate slides into and it tighten it right up. No more rattling ass tail gate. On the bed itself, I just softly tapped down the tabs that the latch hooks to. Simple chit, but made my azz end a little less rattlely. | |
| Subject: Re: tips and tricks Thu Apr 11, 2013 2:41 pm | |
| I had the inside of the bed linex'd and the back of the bed facing the cab. Nooooooooo rattles.
| Subject: Re: tips and tricks Thu Apr 11, 2013 2:54 pm | |
| I seen something at Jamses house that might fix all the bed rattles. But both of those are great ideas. | |
| Subject: Re: tips and tricks Thu Apr 11, 2013 2:56 pm | |
| - T.Rhino wrote:
- I seen something at Jamses house that might fix all the bed rattles. But both of those are great ideas.
Are you gonna tell us ???????? Lol. | |
| Subject: Re: tips and tricks Thu Apr 11, 2013 3:01 pm | |
| I better let him do that. I'm sure he will chime in shortly. But a nother thang I did that helped with noise was insulated the underneath of the center console with sound proofing matting. Helped alot | |
Quadog
| Subject: Re: tips and tricks Thu Apr 11, 2013 3:07 pm | |
| Tip #2
I took the bar off of the outside of the drivers seat. It makes it alot easier to get in and out of without bruising your ass. | |
| Subject: Re: tips and tricks Thu Apr 11, 2013 3:11 pm | |
| - Quadog wrote:
- Tip #2
I took the bar off of the outside of the drivers seat. It makes it alot easier to get in and out of without bruising your ass. X2 on that | |
| Subject: Re: tips and tricks Thu Apr 11, 2013 3:27 pm | |
| My cage was squeaking and making all kinds of noise right behind the seats where it connects together. Remover the Allen head screws and installed some washers behind them and tightened it up. Problems solved. Thanks James!!!!! | |
| Subject: Re: tips and tricks Thu Apr 11, 2013 6:00 pm | |
| Here is how I got rid of the bed squeaking lol | |
| Subject: Re: tips and tricks Thu Apr 11, 2013 9:25 pm | |
| Always use factory brakes and wheel bearings they cost a little more but last a hole lot longer. | |
| Subject: Re: tips and tricks Thu Apr 11, 2013 9:46 pm | |
| - T.Rhino wrote:
- Always use factory brakes and wheel bearings they cost a little more but last a hole lot longer.
Have you tried the EBC pads? | |
| Subject: Re: tips and tricks Fri Apr 12, 2013 6:58 am | |
| No I don't thank so just haven't had luck with the other brands I have used. | |
| Subject: Re: tips and tricks Fri Apr 12, 2013 7:40 am | |
| EBC and oem are both the best. Rest are crap. | |
| Subject: Re: tips and tricks Fri Apr 12, 2013 8:58 am | |
| Subject: Re: tips and tricks Fri Apr 12, 2013 9:31 am | |
| - scottwv wrote:
- x2 on the bearings.
heres a good tip...never follow scott down railroad tracks...lol | |
| Subject: Re: tips and tricks Fri Apr 12, 2013 11:02 am | |
| Always use wet clutch aproved motor oil if not it will burn up your wet clutches. Preferably yamaha brand oil. | |
| Subject: Re: tips and tricks Fri Apr 12, 2013 12:08 pm | |
| Tired of fighting with getting the hood opened on the Rhino? Shave the bottem tab open on the inside that snags on the enclosuer bolt. One hand operation gettting the hood open after that. | |
| Subject: Re: tips and tricks Fri Apr 12, 2013 12:28 pm | |
| Man that hood makes me feel like an idiot. My wife laughed at me the first time I tried opening it up. Any pics, I think I got the concept, but don't want mess it up... | |
| Subject: Re: tips and tricks Fri Apr 12, 2013 12:39 pm | |
| Subject: Re: tips and tricks Fri Apr 12, 2013 1:05 pm | |
| A nother good tip is when working on your rhino always make sure to put the factory bolts back in the right place or your engine builder will yell at you. | |
| Subject: Re: tips and tricks Sat Apr 13, 2013 4:01 pm | |
| Subject: Re: tips and tricks Sat Apr 13, 2013 4:47 pm | |
| - Kenny G wrote:
- Tired of fighting with getting the hood opened on the Rhino? Shave the bottem tab open on the inside that snags on the enclosuer bolt. One hand operation gettting the hood open after that.
I did that and also swapped the bungy hooks that are from the factory.just reverse them so the latch part is on the hood and the fixed piece is in the cab area. james told me about it. | |
| Subject: Re: tips and tricks | |
| tips and tricks | |
