Who is online? | In total there are 30 users online :: 0 Registered, 0 Hidden and 30 Guests :: 2 Bots None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | tips and tricks | |
+27Bayou Tiger 123.bert0621 JOHN DILLARD UnderDawg xjcrawler TrunkMonkey RADICAL RAM rhino727 madmax 1 rhino21 KJrhino SteveS Firefighter REDRHINO64 CUSTOMIZEDRHINO13 Randy3451 chuddly Kenny G scottwv onebuilder flimmy banchee6 Quadog Jet foyota86 T.Rhino WV Hot Rod Rhino 31 posters | |
RiverRat
| Subject: Re: tips and tricks Tue Jun 11, 2013 1:01 am | |
| I like the quick change flags for sure. | |
| | | mike734
| | | | scottwv
| Subject: Re: tips and tricks Sun Jul 21, 2013 11:01 pm | |
| - 123.bert0621 wrote:
- I found the bottom of my bed rattling,so I opened it turned the rubber stops 180* Ok. when ever installing bolts in rotating assembly it is a good idea to use the proper locktite, stuff that will have be removed for maitenance, use Blue,for permanent use red stud and bearing mount, for high temperature use the green,this will save you grief. When bolting disimuler metals use anti-sieze. (blue on bolts,red on my primary nut,green on my stator bolts, a little heat with a flame will loosen any of these.)
DO NOT , DO NOT use thread-locker on the 22mm primary , or secondary nuts !!! I made the mistake of doing that , and had to cut the nut off...which , I might add is , a real PAIN in the ass !!! Heat may let you break it loose ; but , I'm not putting a torch near mine !! | |
| | | ASPENDELLROVER
| | | | mike734
| Subject: Re: tips and tricks Mon Jul 22, 2013 8:42 am | |
| ya know people do look at me funny when i do walk in there. probably think im gonna rob the place. i will go anywhere and do anything for my kids! I have 2 girls 3 years and 6 years old they are all about coloring and crafts so if that's what makes em happy im all about it. next time im there I can pick ya up a fancy rainbow glitter hat. | |
| | | 123.bert0621
| Subject: Re: tips and tricks Mon Jul 22, 2013 11:00 am | |
| You only need little heat to soften with propane torch,acetylene is faster and its better to concentrate right on the nut,then replace it if you can,up here we deal with this stuff everyday,and tons of rust on everything.Never heat till its blue. | |
| | | meats
| Subject: Re: tips and tricks Wed Jul 24, 2013 9:13 am | |
| hey mike does the foam help with keeping the dust down to. | |
| | | mike734
| Subject: Re: tips and tricks Wed Jul 24, 2013 12:50 pm | |
| - meats wrote:
- hey mike does the foam help with keeping the dust down to.
nope just heat and noise | |
| Subject: Re: tips and tricks | |
| | | | tips and tricks | |
