| tips and tricks | |
+27Bayou Tiger 123.bert0621 JOHN DILLARD UnderDawg xjcrawler TrunkMonkey RADICAL RAM rhino727 madmax 1 rhino21 KJrhino SteveS Firefighter REDRHINO64 CUSTOMIZEDRHINO13 Randy3451 chuddly Kenny G scottwv onebuilder flimmy banchee6 Quadog Jet foyota86 T.Rhino WV Hot Rod Rhino 31 posters |
| Subject: Re: tips and tricks Wed Apr 17, 2013 6:09 pm | |
| - rhino21 wrote:
- is there a replacement parking brake cause the stock one sucks pretty bad.
TIRE CHOCKS | |
| Subject: Re: tips and tricks Wed Apr 17, 2013 6:58 pm | |
| socks work for tp in a pinch | |
| Subject: Re: tips and tricks Wed Apr 17, 2013 7:20 pm | |
Last edited by Firefighter on Wed Jun 05, 2013 7:05 pm; edited 1 time in total | |
| Subject: Re: tips and tricks Wed Apr 17, 2013 8:22 pm | |
| Hold your toung out 45 degrees to the right when ever working! | |
| Subject: Re: tips and tricks Wed May 01, 2013 12:23 am | |
| always replace wet clutch with Yamaha oem only not that cheap crap that comes apart an can take out moter | |
RADICAL RAM
| Subject: Re: tips and tricks Sat May 04, 2013 8:13 am | |
| - rhino727 wrote:
- always replace wet clutch with Yamaha oem only not that cheap crap that comes apart an can take out moter
X2 i learned the hard way on this. they came apart and cost me big time. | |
TrunkMonkey
Posts : 13 Join date : 2013-04-25 Age : 44 Location : Somerset, KY
TrunkMonkey
| Subject: Re: tips and tricks Fri May 31, 2013 10:20 pm | |
| Had a roll of 4" house insulation sitting around. I took the paper backing off it, and draped it over the top of the engine, under the cover. It really brought the noise level of the engine way down in the cab. Just did this and have only went on one ride with it. Worked well, but will probably have to replace every couple of rides due to getting wet and muddy. We'll see, but its cheap. I know it won't catch fire, not worried about that. But what do you all think, will it keep too much heat on the engine, do you think it will hurt anything? | |
| Subject: Re: tips and tricks Fri May 31, 2013 11:22 pm | |
| Flimmy what type of tires are those in that picture. And that's good idea for splash guards. | |
xjcrawler
Posts : 16 Join date : 2013-03-12 Age : 55 Location : Flowery Branch, Ga
| Subject: Re: tips and tricks Sat Jun 01, 2013 12:39 am | |
| I'm going to guess these.....26" GBC Dirt Tamers | |
UnderDawg
| Subject: Re: tips and tricks Sat Jun 01, 2013 12:42 am | |
| Subject: Re: tips and tricks Sat Jun 01, 2013 7:56 am | |
| T.Rhino I quoted trunckmonkey so the Rhino in the pic is his. Maybe he will say what tires he has. | |
TrunkMonkey
| Subject: Re: tips and tricks Sat Jun 01, 2013 3:35 pm | |
| - T.Rhino wrote:
- Flimmy what type of tires are those in that picture. And that's good idea for splash guards.
T. Rhino; those are Moto MTC tires. I've been real happy with them. They ride really good to have such a deep lug, and do good in the mud. | |
JOHN DILLARD
Posts : 24 Join date : 2013-03-10 Age : 63 Location : Ohio
| Subject: Re: tips and tricks Sat Jun 01, 2013 3:59 pm | |
| 700 parking brake 1/4 inch hard brass out line old pad on brass flatbar cut out and install. I did this about 300 miles ago and work great no noise either. Seem to be lasting better also | |
JOHN DILLARD
| Subject: Re: tips and tricks Sat Jun 01, 2013 4:04 pm | |
| For all trail/ brush riders window nets is nice. Your wife will love ya LOL. | |
| Subject: Re: tips and tricks Sat Jun 01, 2013 6:40 pm | |
| - JOHN DILLARD wrote:
- 700 parking brake 1/4 inch hard brass out line old pad on brass flatbar cut out and install. I did this about 300 miles ago and work great no noise either. Seem to be lasting better also
On the 700 the parking brake is indeed the parking brake and not also the rear brakes as on the 660's. I would expect to see zero wear with anything, unless you forget to release the P brake when you get moving again? More importantly, does it hold well when you are parked on a steep slope? | |
JOHN DILLARD
| Subject: Re: tips and tricks Sun Jun 02, 2013 9:07 am | |
| It holds great and most would tell ya you are always adjusting the 700 park brake.james has a mod for it that help also. | |
| Subject: Re: tips and tricks Thu Jun 06, 2013 10:42 pm | |
| I found the bottom of my bed rattling,so I opened it turned the rubber stops 180* Ok. when ever installing bolts in rotating assembly it is a good idea to use the proper locktite, stuff that will have be removed for maitenance, use Blue,for permanent use red stud and bearing mount, for high temperature use the green,this will save you grief. When bolting disimuler metals use anti-sieze. (blue on bolts,red on my primary nut,green on my stator bolts, a little heat with a flame will loosen any of these.) | |
Bayou Tiger
| Subject: Re: tips and tricks Fri Jun 07, 2013 12:11 am | |
| Subject: Re: tips and tricks Fri Jun 07, 2013 12:17 am | |
| That's a great idea! Your rhino looks awesome! Good color choice! | |
| Subject: Re: tips and tricks Sun Jun 09, 2013 10:56 pm | |
| Subject: Re: tips and tricks Mon Jun 10, 2013 7:03 am | |
| Subject: Re: tips and tricks Mon Jun 10, 2013 10:11 am | |
| Subject: Re: tips and tricks | |
| tips and tricks | |
